- Oct 22, 2014
- 24,759
I am not a licensed engineer so I have no official comment on the practicality of the information.That is, in any practical way ... less practical than it sounds.
From my research into the issues of heavy weather sailing, my go to is to utilize the "Hove-To" skills I practice yearly, and avoid the conditions in coastal water sailing usng weather forecasting as a practical measure.
The concepts of where to position a sea anchor were explored by the US Navy and studied by the US Coast Guard. The USCG published their work in May of 87 "Investigation of the Use of Drogues to Improve the Safety of Sailing Yachts". The full report can be found here. https://www.jordanseriesdrogue.com/pdf/droguecoastguardreport.pdf
They concluded that the best practice was the use of a "Drogue". The Jordon Drogue was tested and used for the CG report. Practical Sailor (of which Thinwater is a contributor) has published much on the Jordon Drogue.
If I was going to be at sea for a long passage, I would make the $2K investment in a Jordan Drogue sized for my craft and work to never have to deploy it.
The concept of the second wave distance from the boat was identifeid in the CG report. Practical or not, it's application is to maximize the opportunity for the drogue or sea anchor to stay buried in the water and not be pulled out of the water as the boat rises and falls on the waves.
The work of many suggest 100 meters of rode to accomplish this condition is not impractical.
Here is an image from the CG report illustrating what the CG considered.
It is up to each skipper what safety plans and considerations to make, that are practical, for the safety of their crew and boat.
