After having fuel starvation issues I have switched out my fuel filter on my 9.9hp outboard 3 times recently. The first couple of times i was out sailing/ motoring and I switched each filter out a day apart......he 3rd time I cut the filter open and found green crystals in the filter (see attached). Keep in mind that less than 3 gallons of fuel has ran through the lines and the filter. I syphoned out the fuel from both tanks through a filter and there was a small amount of brown sludge left in the filter. I then attached a clean rag to a stick and drained every drop of fuel and small dark particles that I could see in both plastic 3 gal fuel tanks.
They appear to be completely clean now, though I cannot clean the lines effectively.
Prior to this the engine ran flawlessly every weekend for months. I am curious if anyone has experienced this issue? Perhaps is was a bad batch of fuel? Maybe I should filter fuel when filling the 3 gal tanks? Maybe the fuel had a higher ethanol content? I just don't know so looking for suggestions.
