Tahatsu 6hp Sailpro for my Hunter 240
Apr 14, 2018
72
Hunter 240 San Diego
Does anybody have advice whether the Tahatsu Sailpro 6hp will be adequate for my Hunter 240? It is supposed to be very efficient.
ABSOLUTLY!
I had one on my Hunter 26
At hull speed at 2/3 throttle… sipped gas…. Charged my battery bank….. light… started easy…. Can’t say enough good things about it. I always disconnected the fuel line and let the motor run dry… never had an issue.
May 24, 2004
7,202
CC 30 South Florida
Should be good in most general conditions but should you sail in a river or an area of strong currents, high seas or strong winds you may want to consider an 8HP.
Likes: Dolphin55
Apr 14, 2018
72
Thanks, guys! Great advice. My boat came with a Mercury 9.9 but I would like to upgrade the motor - like the lighter, more efficient Sailpro with the charger. But, of course, I don't want to lose too much maneuverability.
Jun 12, 2021
297
Hunter 240 Aqualand Marina, Lake Lanier
I had an 8 hp Honda on mine and replaced it with a 5 hp Mercury propane. It works fine. I bought the standard Sailboat model without the extra long shaft. The mount on the H240 is very low to the water.Fuel Compartment Transom Opening.jpg
... should you sail in a river or an area of strong currents, high seas or strong winds you may want to consider an 8HP.
Strong wind yes... but hull speed is hull speed (through water) regardless of which direction the current is running. If your hull speed is 6 kts and the current is 8 kts, you are not going against the current ... even with a 9.9.
Likes: Dolphin55
Jun 12, 2021
297
It takes a long arm. I dial up he resistance knob so that is will hold a straight heading and then steer with the tiller. It is awkward when you are docking and need to put her in reverse and turn the throttle. It feels like you are falling off the stern. I have the five HP that they make for Mercury and it is only 57 lbs. It would be ideal if I had remote control that I could use while sitting in one of the stern seats. I could easily dock the boat single handed with my boat hook.Mercury on Transom.jpg
May 1, 2021
15
Hunter 240 Southampton
It takes a long arm. I dial up he resistance knob so that is will hold a straight heading and then steer with the tiller. It is awkward when you are docking and need to put her in reverse and turn the throttle. It feels like you are falling off the stern. I have the five HP that they make for Mercury and it is only 57 lbs. It would be ideal if I had remote control that I could use while sitting in one of the stern seats. I could easily dock the boat single handed with my boat hook.View attachment 204594
thanks for the reply, that's what I was thinking, could be a bit awkward when things need to happen quickly.
I have a remote fitted to my boat but prefer the idea of the lighter and more portable 6hp
May 1, 2021
15
Simple. You can purchase a remote control box from the motor manufacturer with parts to attach cables with.
do you know if they can be easily connected and disconnected? my boat will be on a mooring so would want to remove the outboard every time to avoid theft.
Johann
Jun 3, 2004
549
Leopard 39 Pensacola
Great motor. I had the 6hp sail pro on my 23.5 and it was super. I got the high thrust prop which made it behave better docking (ie less thrust at idle) and seemingly better in headwinds as well.
Likes: Dolphin55
Aug 1, 2021
51
Hunter 23.5 Lake Rathbun
I just traded my 9.8 for the 6 to save my back. It should work fine on the lake I think. I was thinking same thing about using boat pole to shift. Will let you know how hard I crash into the dock the first time.
Likes: Dolphin55
-na -NA Anywhere USA
To answer the question about motor hookups from the shift and throttle cables, Tohatsu had easy quick disconnects. It has been many years now since I retired. You will need to talk with a Tohatsu dealder
Likes: SolentHunter
Jun 2, 2004
3,612
The larger small Mercury outboards have a "Grip Shift" throttle.
Twist the throttle one way for forward the other for reverse.
Perfect for this application but I think you must get at least an 8hp motor to have it
