Using your example from 45% to 80% would be 105 AH for Phil’s 300 AH bank. The charger specs say it maxes out at 25 Amps @48V, which should provide decent headroom on a 30A 110V circuit. Assuming 90% charging efficiency (which Google seems to say is pretty conservative for LiFePO4 below 80% SOC) it would take 4.7 hours to go from 45% to 80%.
In any case for Phil’s use case an overnight charge after a run like that sounds pretty manageable. If most of his motor use is in and out of marinas anyway then it’s a non-issue. Keeping the speed to 2 knots is also perfectly adequate for that kind of use.
I’m with
@jon hansen - this won’t work if you want to motor or motorsail for multiple days on a schedule. But if you want to be able to get your boat out sailing, enjoy the day, and have the occasional longer trip this sounds like a perfectly good auxiliary power setup.
