how to access forward head thru hull on Oceanus 400
JamieB
Aug 1, 2021
46
Beneteau 400 Loano
ok so we have a leak. and I think it's the forward thru hull but I have no idea how to access it on my boat. the whole head is single form with no access and the actual seacock valve is recessed into the form. has anyone done this before?
thanks,
J
Jun 25, 2004
606
Hunter 306 Pasadena MD
You want to access your forward head by going through the hull? Sounds a bit extreme to me...
May 24, 2004
7,224
CC 30 South Florida
Can't believe a boat manufacturer would hide a Thru-hull and valve behind a molded head enclosure. Check for an opening in the floorboards or inside a cabinet. If unable to get a response contact Benetau for guidance.
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
It looks like what you're looking for is located near the forward holding tank. You should be able to access that area?
What's behind the access door?
7,700
Alden 50 Sarasota, Florida
It looks like what you're looking for is located near the forward holding tank. You should be able to access that area?View attachment 201101View attachment 201102
He said "forward (head) thruhull".
He also didnt say he was planning to access the head via the hull (topsides).
As Benny said, there is access likely behind the cabinet as with most any boat which provides access to thruhull seacocks.
Apr 27, 2010
970
The forward head intake is behind that access door and the forward head discharge is under the sink. :huh:
As shown in those diagrams. What's your problem.
Ward H
Nov 7, 2011
3,837
Hey @JamieB On my last boat it looked like the thru hull was installed into the hull, then the liner went in with a small hole over the thru hull stem. Then the valve was screwed onto the stem so that you could barely see the thru hull and not reach it.
Is this the issue on your describing on your boat? You can't see the actual thru hull?
JamieB
Aug 1, 2021
46
Beneteau 400 Loano
This seems like it maybe the case. The sea cock for the in take is coming through but there is no way to access. Is it that I would need to access it if it's molded into the hull??
Thanks for the help
JamieB
Aug 1, 2021
46
Beneteau 400 Loano
A storage locker and a molded wooden plate that has been siliconed in place. I was thinking of cutting a hatch through.
Access from the forward tank is also blocked. Seems so strange that they wouldn't make it easily accessible.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Oh of only it were that easy. I suppose the bigger problem is owning a boat
Yes, and, in this case, it's a boat built by someone not interested in owner maintainability.
Apr 27, 2010
970
That comment was not directed at you but @Don S/V
If the boat was built in The USA at the Marion Plant SC, Give Ward Richardson a call. He is very Helpful.
Good Luck
JamieB
Aug 1, 2021
46
Beneteau 400 Loano
Exactly. The mechanic came and said we'd have to cut a bigger hole as a lot of beneteau were built like this. I'll be trying to install some hatch so it will be easier to access in the future.
JamieB
Aug 1, 2021
46
Beneteau 400 Loano
Good Luck
Ah thanks so much for the heads up. I'll give him a call.
