Looking for advice. Crusair supply valve
Jul 7, 2004
8,497
Hunter 30T Cheney, KS
Looking for issues I ought to be fixing in the off season. I'm already flipping my fresh water pressure pump because it is installed upside down. More in a future thread.
This setup was installed by a PO for winterizing the Crusair AC/Heat system. You shut off the thruhull valve and open the inline valve to feed RV antifreeze thru the nylon tube. It works well but I think I ought to replace the garden faucet with something nauti. Any recommendations?
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
Probably less of an issue in fresh water but still should be gone. Groco makes a flush kit for these type of connections.
Looks like a DIY plumber with a Lowes credit card rushed the boat to create a usable winterizing system.
A workable solution for you. The better ball valve is a good solution.
JRacer
Aug 9, 2011
1,376
This has possibilities. Ball valve with hose bibb
That is similar to what I have. But, no hose connection. Mine just has the hose clamped on the input end. I just stick a funnel in the end of the hose, turn on the AC compressor so the pump runs and pour in the pink stuff until it pumps out the AC outlet on the side of the boat. Best photo I have handy. Bottom right is the valve.
Likes: Justin_NSA
