In that case, rig up the other lines (outhaul, downhaul and halyards, etc.) with cheap string, remove it and measure. Guidelines for measuring line lengths Selecting Rope - Length, Diameter, Type - Rigworks :.....I hate buying that expensive line and have a bunch left over.
Here are the specs for the Widgeon rigging, taken from my Expanded Owners Manual. The specs are actually from 1979, but matched what I had on my 1969 model which should match your 1965 model. I have attached a diagram showing the rigging of the mainsheet and jib sheets as well. Any other questions? Let me know!!
O’DAY WIDGEON RIGGING SPECS
(Taken from a 1979 O’DAY memo and measurements off my 1969 Model)
Running Rigging Specs.
All Lengths and specifications are approximate and are subject to change without notice
Main Halyard: ¼” x 37’
Jib Halyard: ¼” x 26’
Mainsheet: 5/16” x 36’
Jib Sheet: ¼” x 16’ (8’ each side)
Mainsail Outhaul: 3/16” x 8’
Boom Downhaul: 3/16” x 3’
Spinnaker Halyard: 3/16” x 27’ (mine was ¼”)
Spinnaker Pole Lift: 3/16” x 13’
Spinnaker Sheets: ¼” x 20’ (2x)
All running rigging is typically double-braid Dacron (Polyester) rope
Standing Rigging Specs.
Head stay: 3/32” x 12’5 ¾”
Upper Shroud: 3/32” x 12’9 ½”
All Standing rigging is SS 1x19 type wire and lengths are with turnbuckle (where applicable) closed, from eye to eye (most riggers measure with turnbuckles half-closed, so be sure to note this and/or bring old rigging to rigger to measure for replacement)
Hello sunbird can you tell me why the mainsheet line is so long ThanksHere are the specs for the Widgeon rigging, taken from my Expanded Owners Manual. The specs are actually from 1979, but matched what I had on my 1969 model which should match your 1965 model. I have attached a diagram showing the rigging of the mainsheet and jib sheets as well. Any other questions? Let me know!!
I get it now instead of one line going out when letting the sail out there is actually 2 lengths going out?? Why so long?
Well, if it were shorter, you would not be able to let the sail out all the way! <GRIN!>
But, if your boat was set up with an aft traveler as shown in the attached diagram the main sheet may be shorter. That 36' length was the length of the main sheet on my boat, but I had the setup as shown with the triangle tackle at the stern. I have attached 2 pictures of my old boat, one at the mooring showing the main sheet, and one while sailing where you can see how much line is needed when the sail/boom is all the way out.
