Stern light
MikeyJ
Dec 15, 2018
41
Hunter 23.5 Carlyle Lake
Was the design of the Hunter 23.5 intended to drag the motor when sailing at night? If I raise the motor it blocks the light. This is with a factory motor attached to the factory mount.
Happens on a lot of boats. Many skippers have bitten the bullet and installed another light where it can be seen and disabled the original one.
Likes: Sailfanatic
MikeyJ
Dec 15, 2018
41
That's what I'm thinking of doing. I think people would see me with the sails up but just to be safer and legal.
It has been my experience that time spent dealing with nav light function (running down a short, burnt bulb, cracked lense, etc.) far exceeds the amount of time we actually sail at night. I keep mine working to be legal but assume they won't work when I actually need them.... so I keep a set of these on board.
If it were my boat, I would not spend time moving the stern light and just stow a light I could clamp onto the stern rail when I needed it.
2 cents.... YMMV
Likes: SFS
SFS
Aug 18, 2015
2,100
Currently Boatless Okinawa
2 cents.... YMMV
This is one of the best posts I've ever read on this forum. @MikeyJ - you cannot go wrong following this advice.
Likes: rgranger
Jul 19, 2013
390
Pearson 31-2 Boston
2 cents.... YMMV
This light set is a powerboat running light setup as it has a 360 degree white light, so it would not solve the OP's problem, as his issue is proper lighting when sailing. That said, I would rather use the 360 degree white light, and risk confusion as to my vessel type, than sail with an obscured stern light, which would be a game of Russian-roulette.
Best to relocate the stern light to be legal, and shame on the builder for putting out a boat with an improperly positioned stern light.
Jul 19, 2013
390
Pearson 31-2 Boston
PS I looked a few photos of the Hunter 23.5 and they show the stern light mounted on on the starboard side of the transom, which is immediately adjacent to the OB. I suspect that if you just relocate the light to the port side of the transom, you may solve your problem. A stern light displays 135 degrees, measure the angle from a portside light location to the back of the engine, and I suspect the engine will not be within the 135 degree arc.
Is so the builder could have just as easily shipped the boats without the problem.
This light set is a powerboat running light setup as it has a 360 degree white light, so it would not solve the OP's problem, as his issue is proper lighting when sailing. ...
True...
Plese add 3" of duct tape to my earlier post.:biggrin:
On a serious note.... I got curious what the actual regs state and found this...
If your boat is greater than 39.4 feet but less than 65.6 feet, or 20 meters, you need the following set of navigation lights:
  • A masthead light is a white light at the front of the boat. The masthead light needs to be visible across 225 degrees and from two miles away.
  • A stern light, which is a white light at the rear of the boat. The stern light needs to be visible across 135 degrees and from two miles away. When the masthead light and the stern light are combined, that makes up 360 degrees.
  • Finally, you need one pair red and green sidelights that are visible across 112.5 degrees and from a distance of one mile.
So I don't think the 360 is illegal on a smaller boat. It would only be a problem if you were also running a masthead light.
MikeyJ
Dec 15, 2018
41
From what's I understand, while sailing you turn off the mast head light. So people know you are a sailboat. The nav lights on the front and stern light remain on whether sailing or motoring.
Jul 19, 2013
390
Pearson 31-2 Boston
You are losing track of your light options. While you could legally use the 360 white as a combined stern light and masthead (steaming) light, since its a combined light, you would not have only a stern light for when you are not steaming (under power). The combined light is fine for a power boat which always uses both, a 360 doesn't work for a sailboat.
MikeyJ
Dec 15, 2018
41
I agree that it will be too much trouble to relocate the stern light. So I'm going to add one to my back pulpit. Now another question. I'm guessing I need to take the bulb out of the original light. Or, can I leave them both on?
-na -NA Anywhere USA
On many inland lakes, power boat drivers generally look straight forward , never upward. In other words, make it at an eye level so those power boat drivers “see the light”!
Likes: MikeyJ
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
Details.:banghead:Just another example of why it takes much longer than it should to change or fix anything on a sailboat. It doesn’t fit, it’s not the right type, there’s no good spot, it fits but doesn’t work as it should, someone before tried it and now the whole thing is a CF. “I can’t believe that little thing costs so much:doh:!”
Aug 12, 2018
163
Hunter 26 Carter Lake, Colorado
On the H26 (and maybe the H260?) they eventually put the stern running light on the stern rail (see it above the tiller in the attached photo) but there is still a blank pad molded on the right transom in the original location.
Thats a nice location and BTW: I really like your tiller....:beer:
