Okay all you wizards of wind... this is a world renowned physics claiming a wind driven vehicle can be made to go down wind faster than the wind —- mind blown!!!!
No, an ice boat does essentially the same thing as a sailboat, just with less drag. This is quite different because it's the mechanical connection to the ground that makes it possible. Because the wheels are on the ground, the prop is driven at a speed that puts the airfoil section of the prop at a "broad reach" angle relative to the wind. Without that, this wouldn't be possible.Don't ice boats do that?
Exactly. The clever part was in realizing that, although the vehicle is going dead downwind, the airfoil section of the prop isn't.So going faster than the wind dead downwind is thought to be impossible. But seems if you are clever it isn't.
I love this perspective.An even simpler way to think of it would be to attach a post that can pivot at ground level. If the wind pushes just above the base of the post, the top of the post will move faster than the wind.
Folk around the world say we should tap that power. Build boats to sail across the oceans. No need for oil. But wait we have done that.there is a lot of unrecognized and untapped power in the wind.
I'm not prepared to say you are wrong, but this guy has a tremendous reputation as a science educator and a PhD in physics from Syndney.stupid is as stupid does
Well for a sailboat to make better than the wind -- down wind-- it has to gybe downwind. So, it is not sailing directly down wind and the answer is no... a sailboat cannot sail faster than the wind if it is sailing directly down wind.Didn't watch, but hasn't this already been demonstrated?
Directly up wind too.
By using a spinning propeller they’re leveraging the same effect as a sailboat gybing. In both cases the foil is going with the wind and across it, generating lift to pull the vehicle downwind. A sailboat gybes because it can’t keep going to one side indefinitely. The propeller spins around the hub to change directions.Well for a sailboat to make better than the wind -- down wind-- it has to gybe downwind. So, it is not sailing directly down wind and the answer is no... a sailboat cannot sail faster than the wind if it is sailing directly down wind.
