Halyard wrap with Furlex
kbgunn
Sep 19, 2017
231
2005 Hunter 33 Lake Lewisville, TX
New-to-me 2006 Hunter 38 with a Furlex 200s. If there is any tension on the jib halyard, I get halyard wrap while furling up the jib and cannot furl the jib up completely. See photos below. When all tension on the halyard is released, the wrap resolves and I can completely furl up the jib. I figured this out through trial and error in some dicey conditions with the jib and sheets flailing around. Is this normal behavior? I have a Selden fractional rig and the halyard exits a sheave box which is the recommended configuration in the 200s manual. I have cleaned and lubed the upper swivel so that it spins smooth and freely. I had a Catalina 30 with CDI furling gear and this didn't happen. Any suggestions for troubleshooting appreciated.
Mar 6, 2008
1,429
The wrap is due to the head of the jib too far away from the top of the furler. The jib needs to be raised about 10". This can be done by placing a pendant at the tack of the jib to raise it. You can make a temporary one using a loop of line.
Haro.
Likes: kbgunn
Ted
Jan 26, 2005
1,274
Dave is correct. Another type of halyard deflector is the one made by Harken it's very easy to install.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
There's likely a furlex version as well, I will check with Selden
Mar 23, 2020
12
Hunter 30G Nanaimo
If you have a back stay tensioner, adding some tension before furling also helps.
JRacer
Aug 9, 2011
1,382
Yep. Wrong angle for the halyard. Not the furlers fault.
Jul 7, 2004
8,502
Hunter 30T Cheney, KS
Haro.
That's exactly what I had to do. In fact, the manual says a pendent longer than 6" should be wire
Likes: kbgunn
Jul 7, 2004
8,502
Notice in that figure how short the exposed halyard is. No chance for a wrap. Install a pendent at the drum and lessen your exposed line
Likes: DrJudyB
kbgunn
Sep 19, 2017
231
Haro.
I think this is a good observation and will be easy to confirm. It also agrees with the drawing in the manual I just posted above. Thanks for the suggestion. I'll work up a pendant today. :thumbup:
kbgunn
Sep 19, 2017
231
Thanks Justin. Did you swage your own wire pendant or is there a ready-made source online?
Jul 7, 2004
8,502
Funny you ask. The PO used a piece of line and referenced a piece of tape on the furler when he tied it. I just happened to find this ready made pendent in all of the stuff he gave me. It fit perfectly with a couple shackles I had around.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Here are the Selden numbers for their halyard restrainers:
For 100 or 200: 508-159-01
For 300 or 400: 508-128-01
Give me a call if you'd like to order
877-932-7245 x116
Mon-Fri, 9-3:30 Pacific
kbgunn
Sep 19, 2017
231
Raising the head of the sail further up the extrusion reducing the halyard angle and leaving less exposed worked. No more wrap issues.
Thanks all.
Jun 25, 2004
1,109
Haro.
Or add a pendant to the head, instead of the tack. Your choice.
Mar 6, 2008
1,429
The jib must be raised reducing the length of the halyard at the top that causes the wrap. Adding a pendant at the top will not help.
Jun 25, 2004
1,109
Respectfully, that’s incorrect.
Adding a pendant to the head usually is usually preferred, because that maintains the height of the clew and the vertical sheet angle, which in turn controls leech twist.
adding a pendant at the tack raises the clew and the whole sail, which isn’t generally desirable, unless it’s a really short pendant being added to correct a clew that’s too low for the position of the sheet block.
Judy B
Sailmaker
Authorized Selden and Harken Dealer
