Maybe obsessive compulsive disorder (OCD) is a little closer. Or as we in the group like to call it CDO.Not true.
Maybe you could tell my wife some time.
No Richard that is the original Engine.Repower with an engine / transmission that didn't really fit?
Thank you for the great and well written reply. My engine doesn’t have any odd vibration or knocking, I changed the propeller and all wet relations to the axle. It is aligned and balanced.The Dripless Box is not original equipment for the 2001 h320. We do not know what was done during the installation. It seems the transmission coupler is sitting about 3 inches back from where it should be positioned, but it could be the angle of the photos. Don't know when you purchased the boat or if a recent survey was conducted, but if it was, check and see if the issue was mentioned and perhaps bring the surveyor back to look at it. They have Errors and Omissions insurance coverage which could help with the costs of any repairs in case he missed a fault here. Are there any drive train vibrations or undue knocks ? Don't go by what the motor mounts look as they could look new and the rubber be detached, split or simply soft. The best test for the motor mounts is to see how they perform. Check for any modifications around the seat of the motor mounts and check and see if the correct ones were installed. Could it be a fault during the manufacturing process, yes seems the workers tend to creatively fix problems that arise with or without the knowledge of the Company. In any instance the exposed wood should be repaired; allowed to dry, bathed in epoxy and glassed over.
You might look to verify that.The dripless packing may look overcompressed but PYS changed the bellows design and they now look like that when installed.
I will keep you posted.In the photos the front engine mounts are at the ends of the stringers. There does not appear to be enough room to bring the engine forward, at least with those mounts. When out of the water you might want to check shaft alignment in the stern tube. The dripless packing may look overcompressed but PYS changed the bellows design and they now look like that when installed.
Looks nice!!
Nice looking finished job.It is not finished yet but right now looks like this
