My old ST30 depth transducer did not work. I have purchased a ST60 depth instrument and ordered a new plastic Airmar transducer. I have an old transducer in place on one side forward of the keel with a plywood backer inside the hull (hull is solid fiberglass). I also have another transducer hole on the other side of the hull with a dummy plug that does not have a plywood backer inside. The old openings do not leak. I will have to re-drill one of the openings for the new larger diameter (2") Airmar transducer. Which hole would you re-drill?
