I purchased a 27' sailboat and there were a number of lines on the boat other than mooring type lines.
A rigger looked at the jib and main halyards when I was having the bottom painted and stated the lines were to small to risk having someone use them to go up the mast. He said I needed 5mm or larger lines. I have sailed the boat using the halyards, so they were adequate for raising sails at least. This has me questioning the quality of the other lines on the boat.
Is there some way to look at the lines or cut into an end to see if there is a certain type of core or braided line inside the outer covering to determine if the lines are junk or worth using?
See the photos attached.
Any thoughts are appreciated.
s
s
