- Oct 22, 2014
- 24,708
Questions:
If you want to run down to the boat and go out for a couple hours of sailing, you will be paying to keep it in the water (marina). Hobby Money.
Good luck. I consider Cal boats good boats to sail. I speak from a bias. I have one and know several owners that have them. Welcome to the forum.
- What do you think? Anything stand out?
- Pictures, if from the Sales Listing are "Marketing Pictures". For a boat $7500 is not a lifetime of savings. But it is not chump change for most. You need to examine the boat with an eye for "dangerous issues". These are the type of issues that a Survey will highlight.
- Such as corrosion of through hulls,
- Corrosion of engine systems,
- Corrosion of chainplates
- Leaks in the boat that may sink her
- Moisture in the deck near the mast base.
- Water lines in the bilge that may indicate damage to the integrity of the hull.
- You need to take pictures of the critical areas.
- Mast base.
- Shroud and stays
- Chainplates
- Rudder steering systems (wear, damage or corrosion)
- Anchor, Chain, rode, windlass, storage.
- Base of forward stay, connection at the base of the fore and stern stays.
- Keel and hull - looking for imperfections
- Currently listed for $7500, does that sound right? .
- Perhaps
- How are the sails... They will cost about 3500 to replace. You need to see them raised on the boat or plan on purchasing new ones.
- How is the hull. Could cost 1800 to fix blisters and re paint
- You have about 500 to 900 in cost for replacement of life lines. The current ones look to be plastic covered. You need to look closely at the lines for rust. They are life lines. As you look at them would you trust your life to them should you be swept into them. THEY LOOK TO BE LOOSE - SAGGING in the images.
- Are you ready to buy new running rigging?
- What do the stanchion bases look like?
- What is the condition of the winches?
- You should find a rigger to come and take a look at the standing rigging. Even if you do not do a survey.
- What things do I want to check/ ask about when buy a Cal 2-27?
- The images that caught my eye are the area of the bulkhead below the chain plate it looks like something happened or something is missing. There is a color change of the finish below the chainplate.
- Does the door to the head close completely or does it get stuck?
- The Atomic gas engine. Gas in a sail boat is one that can be an issue. More so then on a power boat. Being assured that the engine will function is a critical issue for you to use the boat safely.
- Does it makes sense to get marine survey for something like this?
- That is a personal call. How much will a survey cost you? Is the boat has issues how much are you ready to put into it to get it safe to sail?
