Hi All!
We just bought a Hunter 29.5 (we’ve been calling her Against the Wind) and are in love with her! Fair warning I am totally new to sailing (grew up with motor boats) so please forgive me if my vocabulary is incorrect.
We’ve decided that before we take her out that we wanted to get everything cleaned up and running right. While my boyfriend is working on the motor and the mechanics I’ve been stripping the vinyl off the walls (or is it ceilings?) due to minor window leaks, and water spots there was a lot of mold and mildew to clean up.
I’m looking for help with refinishing the walls of the hull now that the fiberglass is visible.
I have stripped all the vinyl and foam, and took to cleaning off most of the glue as well.
We know that we want to insulate the walls, and are looking into different options (some being a rubber foam, or bubble insulation) but on top of that we are also looking into applying peel and stick wall paper or paneling instead of the foam vinyl again. The problem at hand is that the fiberglass is uneven, and not just in its texture but is literally uneven in its shape and I am concerned that if we apply and glue down a flexible material that it will show these imperfections even when finished.
So, question:
What is the best way to build up the fiber glass in the low areas so that we have a flatter surface to apply finishing materials to? A light weight marine plaster/puddy? I read about fairing compound, but again am trying to level out the walls just smooth them.
Thanks for reading!
So, question:
Thanks for reading!
