Interior Refinishing (Newbie needs help!)
Dec 1, 2020
12
Hunter 29.5 Legend florida
Hi All!
We just bought a Hunter 29.5 (we’ve been calling her Against the Wind) and are in love with her! Fair warning I am totally new to sailing (grew up with motor boats) so please forgive me if my vocabulary is incorrect.
We’ve decided that before we take her out that we wanted to get everything cleaned up and running right. While my boyfriend is working on the motor and the mechanics I’ve been stripping the vinyl off the walls (or is it ceilings?) due to minor window leaks, and water spots there was a lot of mold and mildew to clean up.
I’m looking for help with refinishing the walls of the hull now that the fiberglass is visible.
I have stripped all the vinyl and foam, and took to cleaning off most of the glue as well.
We know that we want to insulate the walls, and are looking into different options (some being a rubber foam, or bubble insulation) but on top of that we are also looking into applying peel and stick wall paper or paneling instead of the foam vinyl again. The problem at hand is that the fiberglass is uneven, and not just in its texture but is literally uneven in its shape and I am concerned that if we apply and glue down a flexible material that it will show these imperfections even when finished.
So, question:
What is the best way to build up the fiber glass in the low areas so that we have a flatter surface to apply finishing materials to? A light weight marine plaster/puddy? I read about fairing compound, but again am trying to level out the walls just smooth them.
Thanks for reading!
Jan 5, 2017
2,490
If you plan to insulate you need to make room for the insulation. I used 1/2x3/4 in. fir for spacers at 16 in.spaces. then insulated between them and covered with t&g cedar. Covering with a headliner material covers a lot of bumps and rough spots as will the original foam backed vinyl.
B1B59CCC-E58E-42B2-BBA8-AFB632738D9A.jpeg Under construction
0EDDF8DF-9B1B-4462-B90B-CF1DD76CE0A0.jpeg Head liner installed. I did this first in what I call my tool room and will make some changes in the next part. Everything is a learning experience.
In the world of boating, common words often have very different meanings. As you note, the "walls" in a boat are either bulkheads or ceilings and the floors are not the thing you are standing on, which is the sole, but the timbers (or frames) that hold up the sole. Anyway, I digress.
@Michael Davis is guiding you in the right direction. It is possible to sand the bare fiberglass a little to remove some of the roughest points and then paint with several coats of high build epoxy primer and then cover with some sort of fabric or carpet. Whether the underlying fiberglass prints through the covering will depend on the covering, a thin vinyl will probably print through a lot, carpet, not as much.
A more elegant approach is basically the approach Michael used. Clean up the fiberglass and glue furring strips to the ceilings with a few gobs of very thickened epoxy (peanut butter consistency). Align the strips so the surface is fair.this will provide space to add insulation. This approach will provide a several finishing options. Cover everything with ¼" door skin plywood and cover the plywood with vinyl, or use 1" x ½" wood strips of the wood of your choice. Secure the strips with bronze screws. Or use bead board from the local big box HW store. There probably other creative ways to accomplish this.
To control the mildew look for the articles on this in Practical Sailor. Forumla B is a good preventative and environmentally friendly. Air circulation is also important which the furring strips can help provide.
Good Luck! Enjoy the fruits of your labor.
Dec 1, 2020
12
Thanks, yea we’re getting there now that rainy season is done here. That last tropical storm we had was a blessing in disguise, showing us all the spots we may have not found til next summer.
DArcy
Feb 11, 2017
1,788
Islander Freeport 36 Ottawa
Ha, that's what happened to me. I thought I had the leaks sorted... and then it rained. I'll be going through this same effort soon, replacing the foam backed vinyl liner. I plan on using white bead board over epoxied in battens and foam insulation similar to what @dlochner described
PaulK
Dec 1, 2009
1,537
Sabre 402 Southport, CT
One caveat: covering the inside of the hull with sheets of beadboard or doorskins will be really tricky, because the sheets only want to bend in one plane, and the hull is curved in two directions at once. That is why ceiling (the covering on the inside of the hull) is usually made of strips, as has been suggested. It would be smart to varnish the strips before screwing them into place. The finish will be less likely to have sags and drips, and you will probably have better light doing the brushwork outside of the boat so you can see what you're doing. The overhead can be done the same way, perhaps painted white instead of varnished, or with wider strips. Plywood might work on the overhead because the bends aren't generally as pronounced.
Jan 5, 2017
2,490
I used 1/4x 3 t&g in the aft state room where the compound curves are the worst. In the V-berth I used 1/8in. plywood as the curves are less. I spent some time in the boat with a bunch of cardboard and a box cutter to make a template then cut the wood at home. That worked out pretty well as I only had to do minor adjustments with a hand plane. Will be doing some more this winter.
Jan 24, 2017
672
Hunter 34 Toms River Nj
Welcome and cod grats
how much insulation are you looking for and why? Your profile shows you are in Fl. Are you looking to aircondition the space? A cheap method to insulate is 20 foot roles of foil heat shield. It's is bubble wrap with a layer of foil on both sides. Looks like the same material that is used on car windshield shades.
Easy to install with spray adhesive and conforms to just about any shape. Great stuff and reflects a lot of heat.
Hope this helps
Dec 1, 2020
12
Hope this helps
Thanks! Yea, just something as a buffer more or less for insulation. We have A/C so we are hoping to help with keeping the cool in and heat out.
The vinyl foam that was originally applied was no more that 1/2in or so.
I’ve read about the bubble insulation. That might be our route.
Dec 1, 2020
12
That’s a great idea for making a template. Definitely using that!
Dec 1, 2020
12
Hope this helps
Dec 1, 2020
12
The more I thought of it the more questions I had. I think the bubble insulation is a great idea, seems simple but effective. Has anyone used something more dense? My boyfriend keeps bringing up rubber padding as an insulator (much like a yoga mat material) mainly for cushion, although I don’t think we need it. I know air space is key to insulating, was just curious if anyone had any thoughts or if they have tried it?
First, bubble wrap, the packing kind and the kind we all like to pop is not the insulation you want to use. The brand to look for is Reflective (see link below). This has both air pockets and a silver coating to reflect heat. It comes in different sizes. Another advantage is its smooth surface. Mold and mildew seem to like coarser surfaces over smooth surfaces. Could be why the grout in the shower gets mold before the tiles.
I suppose a yoga mat would work, however, if it is an open cell foam, it will absorb moisture which is not what you want. Even if it is closed cell, cutting the foam to fit will open up cells. Nice homes for moisture and mold/mildew.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
On a side note. We probably get just as hot, although not as humid as FL. The best addition to Bella was a full deck, minus cockpit, cover. It keeps the sun off of the deck and has an airgap for circulation. It makes a significant difference on the temps below when we are in the slip. Also protects the 'glas, windows, and lines.
Don't look at it like a Band-Aid though. You should still fix the leaks. :thumbup:
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
DArcy
Feb 11, 2017
1,788
Below is a you tube video of a couple that insulated their old boat
for hatch covers, companionway covers you might want to look at incorporating this material into your covers. From Lowe’s.
finally for full boat covers to keep the heat down and not have your AC work as hard look into these sun shades.
That's a good example of poor material selection. The "gym mat" stuff they used is poor insulation and more expensive than the Reflectix foil backed bubble roll that Dave linked above and will likely hold mildew much better. The one advantage to it is it is it is fairly durable and could be left uncovered, although not an attractive finish.
