1 1/2” vs 1 1/2”
malyea
Dec 15, 2009
236
'87 Irwin 43 Sea Breeze
Installing 1 1/2” SaniFlex hose. The Y valve (measures 1 1/2”) fits easily into the hose but the 1 1/2” elbow doesn’t fit easily (because it measures 1 5/8” ... bought at Ace Hardware). What elbow do I buy to fit the 1 1/2” SaniFlex hose? Thanks!
malyea
Dec 15, 2009
236
Any chance of damaging the SaniFlex hose by stretching/forcing it on to a barb 1/8” larger than its 1 1/2” diameter?
Dec 31, 2016
319
Beneteau Oceanis 351 Charlottetown
The one you bought at Ace is likely 1 1/2" pipe size, measured inside .
malyea
Dec 15, 2009
236
Domestic plumbing fittings are sized according to the ID...marine hose fittings use the OD to fit into hoses, which are are sized according to their ID. 1/8" is quite a bit to stretch a hose....it can cause small tears to develop. I'd return the one you bought at Ace and buy a marine 1.5".
--Peggie
Thank you!
Nov 26, 2012
1,653
Hunter 34 Berkeley
I went through this recently my own self. Bought fittings at ACE because price. I managed to make it work but boy were my fingers sore afterwards from wrestling the hose onto the fittings. The next size down at ACE is 1 1/4" which is too small. West Marine has the more correct sizes but we are talking $12 instead of $1.50 per fitting. Good luck.
Dec 2, 1997
8,722
- - LIttle Rock
I had no idea that plain ol' plastic thread-barb hose fittings could be impossible to find any more! I spent over an hour trying to find 'em in PVC, any type of plastic...Nobody except Shields even seems to make 'em any more and I could only find two retail sources for those--WM and Jamestown Distributors whose price was 50% higher than WM!
Sorry!
--Peggie
malyea
Dec 15, 2009
236
Sorry!
--Peggie
Dec 2, 1997
8,722
- - LIttle Rock
It might if one end were threaded AND it's stated size is the OD (see post #8 above).
Malyea...those are nylon fittings. Nothing wrong with that, but I wonder why nylon didn't turn up anywhere in my search for "plastic tank fittings."
--Peggie
