I have a 2007 Hunter 49 that I purchased recently. I am planning to install rigid solar panels on to the existing davits and arch structure. Looking for ideas/advice on:
1) Where others have installed the MPPT controller?
2) Where wires were fished/routed from the panels to the controller?
3) Where did you connect the pos and neg wires from the controller to? Did you use the positive and neg bus bars closest to the batteries?
4) Anything else that you think is helpful or you learned with your installation.
I have attached an image of the wiring diagram that matches my boat set-up (Optional Inverter System Layout) to assist with any responses. Appreciate the advice!
