Catalina 22 won't turn at low speeds
May 22, 2020
76
Catalina 22 Iowa
Hi AI
Back to the drawing board.
the outboard motor was pointed straight ahead so as not to affect the steering
The outboard motor could be the culprit. You should be able to raise it with the mounting bracket.
Then lilt it so the leg and prop are clear of the water.
Even if this is not causing your steering problem , it is considered "bad form" to sail with the leg in the water.
Best of luck with sail trim, too.
P.S. I would not tow the boat with the motor mounted as per photo.
gary
Well heck, I didn't know it did that!
There are a few settings on the lower part of the motor that I really have no idea what they do. What do I push / pull to make the thing tilt?
May 29, 2018
665
Canel 25 foot Shiogama, japan
Hi Ai
You admission of lack of knowledge qualifies you as a grotty yachty.
Well Done and welcome to the club.
Every time I come to SBO, I learn something so you are not alone.
I am guessing 10 - 15 HP (number 12 down from the top.) these engines share a lot of similarities even if the capacity is not the same.
Download from here and go to page 30. there is a description of the tilt mechanism.
Gary
76
Catalina 22 Iowa
Hi Ai
Gary
Thanks! I talked to their publication department but they wanted more than $100 for both the manual and the service manual.
-na -NA Anywhere USA
If you have either a Nissan, Mercury or Tohatsu, they all are built by Tohatsu and manuals are the same. As for Bigfoot, no such mfg. what does it say on the cowling? You should be able to access those manuals from the mfg website
As for the hull number the one stated is not it. Assuming the boat is state registered, look on the registration for it.
May 22, 2020
76
Catalina 22 Iowa
Sorry the motor is definitely a Mercury but Bigfoot is part of the model name.
Dec 2, 2003
766
Hunter 260 winnipeg, Manitoba
See if this applies to your motor.
Likes: LloydB
May 29, 2018
665
That is weird.
I hit the Adobe icon on the view column and and it downloaded, for free. Don't tell them that there might be a minor flaw in their business model
Gary
76
Catalina 22 Iowa
That is weird.
Gary
No kidding!
May 22, 2020
76
Catalina 22 Iowa
Update: I went sailing this weekend and tried to deal with the lee helm by letting the jib loose. That helped in some cases but I still had the issue. I will now start looking at the thread for rig tuning.
