I have to fix a leaking fixed port
Dec 2, 2003
210
Hunter 34 Forked River, NJ
I need to know if anyone has re bedded their ports using Butyl ? The port in question is the larger pointed fixed port on a 1984 Hunter 34.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
These threads might help. The first one is on a 1984 Hunter 34.
One needs to think about the product (butyl) and how it is used (needs to be a caulk between two mechanically attached fittings).
While the butyl sold by MaineSail is excellent as a caulk that adheres to both sides of fittings, it is not an ‘adhesive’ with the strength to bond the two sides together.Thus you need to attached the parts using a mechanical method (i.e. through bolting.)
I attached my forward hatch to the deck with through bolts and nuts. I used butyl between the deck and the hatch flange to stop water from entering the boat by seeping under the flange.
Likes: sail sfbay
Nov 6, 2006
10,244
IF your 34 has the aluminum port frames, a butyl/795 fix as Rich Breyer posted is what ya need.. If your 34 has the crappy, brittle, undersized plastic frames (like mine has) then a fix like Allan Hadad suggests is a fine one.. You can do the ports separately, as original, or together as Allan did..
Likes: sail sfbay
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
3M makes a double sided tape for this purpose. The tape is about 1/2" wide and 3/32 thick (approx). I saw on line how to do this. The tape is unforgiving once placed. So the rough steps are to remove all old sealing material on the fibergalss and frame. Place the tape on the frame- check the fit before removing the inner release paper. remove the release paper and stick the frame to the boat. Then tape as needed and caulk.
The thickness of the tape controls the thickness of the caulk (795 is, IMO, the correct choice) If the caulk is 3/32 thick and has an elongation of several hundred % then the frame can move a great deal without breaking the caulk joint. If the caulk joint is only .010" (no tape and frame pressed tight to the fibergalss) thick then the allowable movement is very small. Plan to tape the fibergalss and the frame exterior. Apply the 795 caulk forcing it into the joint up to the tape and onto the fibergalss. I was able to drag a razor blade across the tapes to "tool" the joint. Waited 1-2 hours and removed the tape. If the caulk is not zero thickness at the tape edge you may experience some issues removing the tape.
Hunter 34 Herrington South, MD
I have an 84 H34 and have replaced all the ports including the large ones, which I did years ago and don't really remember. However, on a recent replacement of a leaky port in the head, I used the standard 3M adhesive sealant. I just bought some butyl tape to try out. I think each has its advantages. However, when you look at the opening ports, there is a hole cut in the deck and the port is pushed in and screwed. This leaves about a 1/8-1/4 inch around the port. I used 3M adhesive pushed into that opening to ensure a good seal. I'm not sure I would be able to push the butyl tape into the same opening. The 3M seams to me to be a better seal when you are not attaching to flat pieces which would squeeze the butyl tape and surround that screws. Its the "nooks and crannies" that worry me. You might squeeze in some 3M into the gaps and then use the butyl tape also. Over sealing the H34 is never a bad idea.
