Better Cigarette Lighter Plug
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
I'm sick of the cigarette lighter style plugs. I don't trust them. Looking for alternatives. So far the best I have found is the Anderson Powerpole. Any better suggestions?
Some of the devices we charge through this connection are our batteries for power tools, flood light, handheld VHF, laptops, etc.
Thanks
Catalina 34 Casco Bay
Kinda like the real estate axiom.... Location, Location, Location ! Never had any issues with marine grade plugs inside the cabin. Out where the weather as access it can be different. Those pesky rubber caps are susceptible to sun damage. So the trick is to LOCATE where YOU have access but the elements ( including the sun) don't. I found such a place. I have a Scanstrut pod on the pedestal. No issue to add a power plug. It is oriented to the bottom. So it is self draining ( should any moisture get in), and is very accessible. The sun has little or no impact. It does help that there is double protection ( Bimini and pedestal/wheel cover). Good Luck
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Have you considered plugging in a 12 volt ubs adapter and retaining your cigarette lighter functionality for a 12 v to 110 v inverter, higher amperage devices like a small air compressor, etc.? That is what I use in my truck. Lots of options out there.
Nov 18, 2010
2,441
I have USB separate. This is just to replace the cigarette lighter plugs
pilott
Dec 19, 2016
9
Hallberg Rassy Rasmus 35 Kemah
BMW motorcycles have accessory power sockets - for heated suits and other stuff. I think they are called Hella DIN powerlet plugs. I've always found them very weatherproof. Look 'em up on Amazon for details
May 24, 2004
7,131
CC 30 South Florida
The cigarette lighter plugs have an ejection mechanism for the lighter to retract when hot. Regular 12V power plugs have nothing like that, just a friction plug. Have never had any problems with the regular 12V plugs.
Inside the 12v plug there is usually or should be a fuse.
JRT
Feb 14, 2017
2,048
Anderson Powerpole are very nice that a lot of top RC pilots use on 4-5 figure airplanes and jets with real jet engines. Also used in extreme 3D helicopter pilots at our field. I'd probably leave the single lighter in place just in case but make a powerpole charging connection in a convenient place for you charging needs.
I also use to compete in Ironbutt motorcycle multi day rallies and the BMW heated gear plugs mentioned above are considered the best all weather connects, another good option if your need it in a wet environment like rain for sure.
Nov 18, 2010
2,441
This is a secondary panel I installed several years ago. When I went to lithium batteries I moved the inverter and I don't use that remote any more. Or the 110v outlet below. So I am considering two options.
1) remove the inverter remote and put in an Anderson powerpole outlet connected to the bottom switch.
Convert my devices to the Anderson plug and have extras for the future. I could also make a Anderson to cigarette lighter plug adapter so I can bring the devices to other boats if needed.
2) Wire the unused 110v outlet to the bottom breaker and label "12 Volt Outlets". Install 110v plug on my devices and label them as well. I could make the same 110v to cigarette lighter plug connector. My concern with this is the risk of someone plugging the wrong device into the wrong plug. I could use Euro style plugs with this approach.
With either approach the cigarette lighter style and USB outlets would remain usable.
Any thoughts on the two approaches?
Jesse
Option 1 would be a better choice. Don't mix and match AC and DC receptacles, it is just tempting Murphy.
May 7, 2011
206
Catalina 30 Lake Lanier
We sail on Lake Lanier, N.E. of Atlanta GA. We have a modified triple 12v outlet in the cockpit. One is the normal outlet with cover, one was converted to accept a waterproof ethernet jack and the other for an F connector with RG-6 for an HDTV antenna. We have not had any issues with performance, corrosion, water intrusion, etc with any fitting after a few years exposed to the weather. (Cold, Storms, Sun, etc.) 12v is used primarily for a halogen searchlight.
Nov 18, 2010
2,441
View attachment 178507View attachment 178507
"We sail on Lake Lanier"
We sail the Caribbean. Different world.
JRT
Feb 14, 2017
2,048
Option 1, would not repurpose the 110 outlets like that in option 2. Also it isn't much wire in that bundle exposed but I'd put them in a conduit, even a plastic flexible one for a bit more protection.
Dec 25, 2000
5,737
We have several 12v sockets on our boat and have had no problems over the years. Boat came with one at the nav station and I have added five since, one in the cockpit, two aft cabin, one main cabin and one forward cabin. Very handy for all sorts of electronic devices. Also have USB adapters as well as inverters. Very versatile.
Perhaps we have suggestions if you would elaborate on your trust issues. We use ours all the time and they always work.
Nov 18, 2010
2,441
This is the charger from out MacBook Air.
Dec 25, 2000
5,737
Does the socket look the same, all rusty? No rust in ours, even in the cockpit one. Of course that one is a marine grade unit with a rubber cap/cover. All the others that I've added inside the boat were for car applications. Some pics of ours follow:
Aug 7, 2018
179
Catalina 350 Great Sodus Bay, Lake Ontario
This is what I have @ the helm for USB, less than 30 bucks
ROKK
This may be an option also, good reviews:
another option
