Not sure if you ever completed this project, but I recently did mine. this thread was helpful, so i thought i'd share my experience - It was a PITA until i figured out how to do it. On mine i have PVC fittings at both ends (the hull-side fitting rotates). I was able to get the hose back on by pre-bending the hose, slipping it onto the cockpit deck side fitting, and then rotating the hull fitting by hand so it pushed the hose onto the fitting. I used trident 250 rubber hose, it also helped that i used one size larger than the fitting (hose was 1-5/8, fitting was for 1-1/2 hose). I have a pic i can share if it helps.
fyi i had the job professionally estimated and the yard recommended shields 252 corrugated hose. Another option that i came across in my research that i believe should work is the trident 101/102 sanitation hose which seems to be very flexible, but i have not handled it. hope this helps.
