acrylic window thickness
Aug 17, 2013
1,108
Pearson P30 202 Ottawa/Gatineau
hey everyone, I'm starting to look at acrylic windows for Cool Whip, the supplier lists 3 different thicknesses, ⅛, 3/16 and ¼ of an inch, what thickness would you recommend I go with?
I was just talking to our glass guy about what to use as an underwater window in a boat bottom. He said, lexan is nearly unbreakable, if you can seal it in the opening. The 1/4" is pretty light. Thinner and it gets pretty flexible. If you don't need a big piece, you might just be able to ask for a piece of scrap. My glass guy offered to give me some to experiment with. I didn't have the time to do anything with it, otherwise I'd have gladly taken what he had to give me.
-Will (Dragonfly)
Aug 9, 2019
21
Hunter 340 Coconut Grove, FL
There is a great article in Sail magazine by the legendary Don Casey entitled DIY: Replacing Fixed Portlights. Google it and find step by step instructions and materials. He recommends acrylic (plexiglass) over polycarbonate (Lexan). My windows were 1/4 “ so I replaced them with the same.
Jun 9, 2008
1,818
- -- -Bayfield
Lexan is definitely stronger than acrylic, but it is softer (so scratches easier), while acrylic is harder and doesn't scratch as easily. But, Lexan is preferred - especially for hatches where you might step. If you are replacing existing windows, then I'd use the same thickness.
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
@fred1diver how are the windows held in on your Grampian? Polycarbonate (Lexan) is susceptible to stress cracking so if you are screwing it in, acrylic is a better choice. Also, polycarbonate is more susceptible to surface yellowing and scratching.
I went with 3/16" acrylic on my C&C27 windows, mostly because that is what was the OEM used and it lasted 35 years.
Make sure you allow a little flex in the mounting to take up the difference in thermal expansions between the frame and the glazing material. Ottawa has a very large temperature difference from above +30 to below -30°C.
JamesG161
Feb 14, 2014
7,961
Hunter 430 Waveland, MS
how do you allow some flex?
Only by shape, but don't worry about it if you go with Acrylic. Temperatures changes might cause minor leaks at edges, but only summer to winter changes.
We all suffer that at times in a boats life.
Jim...
Tim22
Jun 16, 2014
255
Hunter 310 Ottawa
I am preparing to replace several of my fixed portlights and come up with a thickness of 3/8" for all of them.
Hi Ralph
I replaced most of my fixed portlights last year and will do the remaining two this year. This will leave only the windshield to be done and I have a lead on a local shop that will mold the curve to fit properly. 3/8 was the thickness I came up with. I followed the instructions at Boatworks Today
. I’m waiting until spring to see if they are still in place before I declare victory!
Tim
Hi Ralph
Tim
:plus::plus:
I've watched this video several times and then went down the rabbit hole and watched a hour more of DIY boat Videos because of this one.
Jan 4, 2006
7,469
Find anything outstanding worth sharing ? ? ? ?
I've collected a library's worth of info to date, some of it contradictory. I have to plan the replacement of all fixed port openings as they are starting to show their age.
The most ridiculous one I've seen to date is supposedly by Catalina (paragraph g), although I suspect it's a forgery, it's just so far out there:
Picked this up from another post by some poor guy who had tried this and was ranting and raving about all his ports being crooked plus a couple popped open after a few weeks.
DArcy
Feb 11, 2017
1,786
I would say the hardest part of replacing windows is holding them in place while the sealant sets. Mine were pretty easy due to the shape of the frame, I was able to hook onto it to apply pressure. A friend had a heck of a time wedging boards in place with enough pressure to hold the new windows in. 2x4s, diving weights, ropes, widgets, and Rube Goldberg contraptions. So yes, I can believe the instructions.
It is VERY important to follow the adhesive/sealant manufacturer's instructions and make sure you use material compatible with your glazing material and the frame. I had to use primers on mine but it worked well. Also, ensure the frame is clean and free of old sealant.
