I snooped around the internet to see if I could find examples of Skookum's rig. I found this one. Good explanation and I like the article on "mods". Pros and Cons of this rig were informative.
Soft traveler
I also discovered that "my" version is often called a two-mainsheet system. Not to be confused with the similar German Sheeting System.
Trimmed in hard, the 46 was able to sail at close to 40 degrees to the true wind. The small genoa sheets inside the side stays so the sheeting angles are quite narrow. The in-mast furling mainsail, built by Elvstrom, was cut quite flat but was drawing nicely. The main sheet uses what is being called the “German sheeting system” since all of the Bavarias are set up this way; the sheeting involves two independent main sheets, port and starboard, that replace the sliding traveler.
You use the windward sheet to trim the sail and the leeward sheet to trim the leech in much the same way you would with a conventional traveler. When it comes time to jibe the main, you can maintain complete control of the boom through the jibe by handling both sheets at the same time, a job easily managed by one person.
Soft traveler
