Seadeck might be better for seating as it is actaully closed-cell. More expensive though. Hydroturf is better for underfoot. In a cooler climate maybe more so. In south Florida even on New years day we can sail barefeet and enjoy a cool wet surface for the feet. The sun will cook the seats dry in no time. Up north, i wouldn't tolerate wetbutt eitherThanks for answering my questions.
The hydroturf doesn't sound like a solution for me if it retains water. Lots of birds seem to use our boat for target practice on their flybys so I usually have to wipe things down before sailing and we have been getting much more frequent rainfall for the last several years (record high water in Lake Ontario this year). The primary reason I would do it at all would be for increased comfort and sitting in soggy shorts doesn't seem to fit that bill
Sorry to hear about the delam thing.![]()
When storing the boat is yours mast up? If so take the boom down at the end if the day. That will keep most birds away. Osprys love hanging out on the sail covers and puking fish guts all over, and other birds can hang out on the boom. By eliminating the elevated horizontal hang out they look somewhere else.
Im bummed out about the hydroturf issue so can't recommend anyone do the same unless the color is white.
Super tempted to cut the rubrail off and cut the luran off the entire top section, then pkace FRP over the foam. But that seems like work.
I love the overall 170 design, just that %!&# ACP has got to go.
When it cools down Ill invent a better way to correct the delamination.
I noticed when putting gorilla glue in the bench delamination access holes that using compressed air to blow the glue around caused the space to fill like a balloon, causing further delamination..I suspect that over time the adhesion across the entire deck weakens. I wonder if we can get glue to spread better using a vacuum as if FRP vacuum bagging. Pressurize the luran to break the weak adhesion area, pop a couple holes, then draw it back to the vacumn. Might be hard to gurantee a tight seal or locate vacuum leaks.
