The steps down into the cabin of my O’Day 28 cover the access to the front of the engine. The panel has a cleat on the bottom then tilts back into position and is secured via a barrel bolt on each side. I’ve talked to another 28 owner who has this setup and who also almost broke his neck when stepping on the top step only to discover one of the barrel bolts had worked loose. Have any of you replaced these barrel bolts on your boat with something else?
