There is no risk if you use Paypal with Ebay purchases, don't receive the goods they refund the payment and more importantly the seller doesn't get your CC info
I was more leaning toward risk the item may not work with your tach. But its less than half the price of the other link I used, so give it a shot and let us know! It'd be great to have a cheap, proven source for those LCDs which seem to go out with regularity.There is no risk if you use Paypal with Ebay purchases, don't receive the goods they refund the payment and more importantly the seller doesn't get your CC info
So, any luck?tfox,
Thanks for the update and ordering source. That's the application that I am using it for, a 3YM30. Hope that my repair goes as well as you and Mark's.
Thanks for checking. Received the replacement display about 3 weeks ago. Trying to get all the exterior in shape before it gets too hot and take care of the engine maintenance also. Then there is house stuff too! The tach project will likely be delayed until July when I will be hibernating indoors escaping the heat. Let you know how it turns out. Meanwhile the dependable Hobbs hour meter is still ticking.So, any luck?
The problems with the LCD hour display are wide spread over many years in my six years of commentary observation. It has been reported the LCD display is failing even on replacement units. In every case I have seen, the hour accumulation continues normally, only the display is failing.
In your case of failing tach needle postion something additional is happening. The tach signal is corrupted some how. It is a good start to examine grounding as well as power supply. The tach needle is driven by a motor controled by electronics that respond to the tach signal applied to the unit. My signal comes from the alternator. You should investigate the quality of this signal in addtion to ground connections.
North Star
Yes original hours will be displayed once LCD is brought back to lifeIf changing out the LCD, will the original hours still display after the correction?
I repaired ours during the off season last year, installed in the spring and it is still working wonderfully.Just as another update on this problem. I ordered one from this site, arrived in mail couple weeks later. Followed their You-tube proceedure and just tried out over the weekend. Worked great. Although I didn't realize I had that many hours on the engine as the meter has not worked for several years......
AK Speedo
www.akspeedo.com
