There will be no further issues with that system, but given the shakeout in the weather, it probably saved some expense at the end of the day.And only if you get your alarm fixed.
So what, in your view, is the best technique for this sort of splice? A terminal strip seems the most solid, but that also does not seem entirely practical in a many situations. Those three-way connectors with the rivet in the middle? A step-down butt connector? Other?Not an atypical find with this type of splice..
Yes but it missed some great bourbon, scotch and the beer that Les brought to share. The stay in Vancouver was sunshine and mild temps by your standards.it probably saved some expense at the end of the day.![]()
Bare copper, not tinned.. These connectors corrode pretty rapidly then fail to make good contact and thus high resistance & heat. They are also notorious for damaging/breaking wire strands when "pinched down".Was that tinned copper or aluminum wire MS?
So, when are you going to finish that job???... Just a thought from someone who has been wiring in boats since 1968.
