Hey all! Following dlochner's suggestion of possibly doing an endoscopy under the cabin sole, I decided to try to get some pictures first with my phone camera. As Dave posted, I believe when the boat was grounded, the shock caused cracks throughout. I have not seen any signs of any stringers. I am probably wrong on this. But following the idea of a concrete bottom as I was told of the ballast area
(see quidnon.blogspot.com/2015/01/concrete-slab-bottom.html?m=1), I am wondering if this is what I have. It looks like the concrete encased the lead keel area which was then encased in fiberglass. At the companionway entrance is the bilge pump-out sump (this had a handheld pump with hose to pump out any water from the sump, but I have purchased an electric bilge pump to install once repairs are made with backups placed in other sealed-off areas. But that is down the road). This sump area is a concrete makeup complete with cracks--some substantial. But what I did not know was that it seems concrete extended up to where the keel trunk joins the lead ballast which I have been in the process of re-bedding (I'll attach that picture also). And it looks like a heavy fiberglass cloth(?) was applied on top of the concrete which from the pictures indicates to me that it has delaminated(?). As far as supports under the floor, it appears to be some type of epoxy/silica mixture on the centerline in three spots--one just forward of the keel trunk where the portapotty would be located aft of the forward berth; one, about 2 feet forward of the sump and another just aft of the sump under and behind the companionway entrance. In addition, it appears that this bedding compound was placed on top of the fiberglass cloth(?)-- (I imagine similar to that Dave mentioned --1708 cloth--that Boat Works video was using on a Bertram foredeck) --for the length of the settees both Port and Starboard. Then it looks as though the interior of the cabin was lowered in place and pressed into the bedding compound. This is all supposition on my part. However, it looks like it may be more expedient to remove the floor of the cabin from just forward of the keel trunk where there is no concrete present and aft to the back of the cabin area under the companionway entrance leaving the settees in place as the storage areas under the bench seats are fiberglass (I previously removed the thru hulls and fiber-glassed over before having the exterior of the boat painted. A question I have is: should I repair the external area first because water drains out of the cockpit and then travels under the hull to the back of the keel? I am thinking it is getting into the keel area through the external damage and as it dries out, it leaves the bluish-gray residue stains on the back and both sides of the rear of the keel.
My next plans are: to check in to the endoscope as Dave has suggested; try to become a member of the Gloucester Sailors group dedicated to Harry Sindle designs as Joe mentioned in my previous post to look for further info on the construction from other owners of Lockley Newports which from my understanding became Gloucester; study more about concrete slab bottoms as with the Quidnon blog I referenced at the beginning of this post; and, to look for someone in my area who might have moisture reader; also, as Selah is on a trailer and I have a tent over the deck of the boat, I need to try to seal the stern area off from the cockpit drain forward to the front of the keel to redirect any water from rain storms and prevent any more water from traveling that route.
Thoughts and suggestions are all welcome. I know some will suggest getting rid of the boat. I knew from the start, this would be a big project and am dedicated to seeing it through--for me and the memory of my wife. Thanks everyone. (Have fun exploring these pictures! LOL)
