Currently have single battery located under aft stateroom aft of prop shaft next to water heater-standard location from manufacture. I would like to double amp hour capacity by adding second battery, primarily to handle frig load while at anchor.
Anyone with a 373 who has made change?
My ideal requirement is both batteries side by side or in reasonable proximity, outside of engine room and between mast and engine compartment. Actually, would be greatfull for any pictures and details on change in wiring both from generator and to panel.
Also, did you change out alternator? I appear to have 80 amp hitachi internally regulated.
My current plan is under port seat but physical size of battery-and thus amp hrs -would be limited. Could modify hitachi to externally regulated
