Connecting breather hose directly to intake silencer inlet in M25-XPB
Mar 6, 2008
331
Catalina 310 Scott Creek, VA
I have been reviewing posts about replacing the intake silencer with a K&N filter. Some have also connected the breather to the K&N. There seems to be no consensus on if this is a good idea or not, however in reply #2 to this post https://forums.sailboatowners.com/index.php?threads/k-and-n-air-filter.157234/#post-1067120 Jessie says he tried it and decided to disconnect. Where should I route the breather line if I go with the K&N but do not connect the two together? The existing hose is 5/8" ID and very flexible. What type of hose is used for this application?
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Yes, I disconnected it. I was watching my oil level. Each time I started the motor and found I was gaining oil. I couldn't really come up with a true mechanism as to why this was happening. I disconnected and have the end of the hose about 1 inch from the filter. Works fine.
Sep 29, 2008
1,930
Catalina 310 #185 Quantico
I still have my breather hose attached to my K&N but in between I added a fuel/water separator. I do not get the oil build up on my air filter and my crankcase is ventilated.
3,014
K&N even sells an adapter to connect a breather hose to the filter, I also have an oil separator on the hose to prevent an oily filter.
Gunni
Mar 16, 2010
5,937
K&N filters are designed to be oiled, it is how they capture debris. If you have a dry K&N it isn’t doing its job. They have no magic capability to make crankcase oil. I simply installed a brass nipple into the rubber end plate of the filter and pushed the breather hose onto the filter. Works great.
Nov 18, 2010
2,441
The only thing I could figure was it was creating too much suction on the breather tube and pulling some fuel past the cylinders but that was a long shot. I couldn't really explain my observations.
Gunni
Mar 16, 2010
5,937
I have worked on diesels that take an amazing amount of time for oil that is added to the fill to make it down to the pan. As a result I ended up with too much oil in the engine because I overfilled it.
Likes: JamesG161
Jan 30, 2012
1,123
Jessie
Your breather is not the culprit here. Do you have an engine driven lift pump? If so - and if the diaphragm leaks - your oil level will rise. It is possible an injector might leak down ovenight but the quantity would be quite low.
Charles
Likes: JimInPB
Nov 18, 2010
2,441
Jessie
Charles
I would agree but it doesn't change the fact that the oil stopped increasing after I disconnected the breather tube. And this was something I monitored for over a month.
