Hi all,
My newer boat, a 1997 Cat30 MKIII has been presenting me with new challenges as I bring her up to my standards.
My latest is the West Marine 20 amp battery charger. I can't find any specs on this model and cannot get it to work. It's hard wired into the panel and has AC power up to and out of the panel switch. Not being familiar with it, I wanted to ask if anyone has had a NO POWER UP situation with this charger? There is no on/off switch or visible fuse and I don't want to start opening it up if it's a lost cause.
Problem number 2 is a leak (hot water system) coming under the cabin sole, under the engine and into the bilge. This only occurs when the engine is running and there are no signs of a leak near the heater, nor on the engine hose to the hot water tank. It seems to be starting under the deck between the aft storage compartment and the aft access to the back of the engine. Has anyone had a leak like this and if so, was it the heater feed hose?
Thanks all and Happy Sailing,
Ralph
Ralph
