- Oct 22, 2014
- 23,808
The engineers made the water pump inaccessible on my 1974 boat. I figure it is about time I replace the impeller. I located the raw water pump. Challenge is that the 4 plate screws are inaccessible. The pump is facing the engine bulkhead. It is about 10 inches from the pump.
Here are some pictures. Any one with some ideas I would be greatful in helping me attack the problem.
You can see the 4 screws on the plate in the first photo. I tried to loosen the straight slot screws with a 90 degree screwdriver. No luck. It was slipping in out of the slot. I was wondering what is the pump like. Can I remove the 4 nuts holding the pump to the engine? What will I find? Likely a shaft. Would there be an index point on the shaft. If I remove the whole pump I can then remove and replace the impeller on my work bench.
Thanks for your insight.
