Help me choose a new compass
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
If I want to seal something above the water line that I will be able to get apart easily in the future, I sometimes use clear RTV calk from Home Depot. I set the parts fastened together with the calk in place, but do not tighten the fasteners until after the RTV has dried. This method works best if you have a very irregular surface under the part that you need to mount. If you need to fill in a very thick area with RTV, you may need to wrap the edge of the part with masking tape to keep the uncured RTV from running out.
If you want to make a gasket instead, then you need to start by checking how flat the mounting surface is. If you have a gap of 1/8" or more under a flat edge, then please consider the method above or consider using a thick foam rubber gasket. If the gap is 1/8-1/16" then 1/4" closed cell foam rubber should work. If the gap is 1/16 or less, then 3/16" 40-duro rubber (outdoor material/grade/color of your choice) should work. Harder rubbers don't conform as well. If the surface appears flat, then you should be able to use most any standard outdoor gasket material.
I think it's on backwards.
Shouldn't the side with the beer tap be on the outside? Otherwise, the cabin ceiling interferes with the tap pull.
- Will (Dragonfly)
Likes: Kermit
Kermit
Jul 31, 2010
5,673
- Will (Dragonfly)
Oh dang! You’re right!
JamesG161
Feb 14, 2014
7,770
Hunter 430 Waveland, MS
Well the RED kind doesn't exorcize the ghost seen in the center of your installed picture, but it will seal out the water.
Did you use a water hose to test your seal?
Jim...
PS: You can use a hot beer to test also.
Kermit
Jul 31, 2010
5,673
Jim...
I didn’t test the seal. Don’t get me all paranoid! And isn’t that ghost handsome!!!
Likes: JamesG161
JamesG161
Feb 14, 2014
7,770
errr uhhhh well I ... errrr...
Dont get paranoid! Since I did verify you your compass works if... that was an ≈3-4pm picture in SC.:waycool:
Jim...
PS: I love being a detective.
Likes: Kermit
Kermit
Jul 31, 2010
5,673
Jim...
Nope. 1:34 pm. I want my money back!
Kermit
Jul 31, 2010
5,673
I have seen lots of discussion about how to dispose of old boats. The old compass ended up in the trash. Sorta sad really.
Oct 28, 2013
678
Hunter 20 Lake Monroe
Have you swung the new compass? Want to make sure it reads right now that it is in your boat.
Our friend put his Bluetooth speaker real close to the backside of his compass. It read west when it was pointing north.
Sam
JamesG161
Feb 14, 2014
7,770
Nope.:snooty:
I guess you took at picture of the west setting sun's reflection at an angle, but the the body was still warm, your honor.:poke:
OR
You used a metal gasket!
Jim...
Likes: Kermit
Kermit
Jul 31, 2010
5,673
Sam
I’ve never swung a compass. It seemed to be pointing the same direction as the old one and where everyone says north is at the club. Honestly, I’d rather have swung a beer tap.
Nov 8, 2010
11,386
Success!!! I bought a square sheet of rubber from Simpson’s Hardware and cut it to fit. Even the screw holes line up. Even the light works. Thanks for y’all’s help, y’all!
NICE
Likes: Kermit
Oct 28, 2013
678
Did the new Compass come with a UV protector cover so you don't have to replace it again in a few years?
Sam
Yep.
I think you are going to have to be careful some rebel pilot doesn't swoop by in his X-Wing trying to take out the power node to an Empire ship, by mistake.
- Will (Dragonfly)
