Thanks again for taking the time to repost that response Main. If as you say, your bench Freedom works fine on a 5mA GFCI, and mine is stable on the yard 5mA GFCI, then would the problem point to the cumulative effect on the dock? And why do I seem to be the only boat affected nearby?
As I understand our setup, the pedestals on the dock are daisychained. Each one has 4 20 amp circuit breakers that each provide power to a dedicated GFCI.
Because it's working in the yard and intermittent in the slip, I'm still confused. Since my charger supply is wired to the same buss as my AC distribution panel then why does removing the line to the unit allow the boat AC distribution work without tripping?
