I installed an Isotherm GE 80s ISEC refrigeration system in my existing icebox. I'm very pleased. First pleased that the existing insulation in the box is thick for a 25 footer. Isotherm recommends 3-5cm of insulation for fridges <80L. Ours is 50L and looks like it splits the diff with 4cm.
Next the install went very smoothly, and the plate fit like a glove.
But the biggest news is the efficiency. The boat has a single Group 29 battery rated at 85 amp/hour capacity. Yesterday as a test I unplugged the boat from shore power at 7AM. It was in the 80s to 90 all day. Fridge is set at 42F. Twelve hours later I came back and checked the resting battery voltage.
That's 90% of full charge, meaning that the fridge used 8.5 amps in those 12 hours, or a 0.7A/hour run rate. Very good, and matches specs and other users observations. That's less than an incandescent anchor light!
