Hello I'm brand new to sailing. Just purchased my first boat macgregor 26d. So I live on the Columbia river and wanna know the ins and outs of sailing the columbia river mostly from Bonneville dam to the dalles dam thanks for any and all info.
Go talk politely with the locals.Hello I'm brand new to sailing. Just purchased my first boat macgregor 26d. So I live on the Columbia river and wanna know the ins and outs of sailing the columbia river mostly from Bonneville dam to the dalles dam thanks for any and all info.
Good one. I'd look for the boats with big sticks and white things on them.do i just hold a sign out that says do you own a sailboat!! Haha
Apparently not local to the river. That river has some current, so it's good know what you're up against.I guess I am the locals...
I couldn't resist....Good one. I'd look for the boats with big sticks and white things on them.
There are plenty of resources available to you (try Google). There have been books written about sailing in that area, which is beautiful - I took a road trip through it many summers ago.
Fair winds, and you'll get a lot of wind!!!![]()
Thanks Ken that's the kind of info I was looking for appreciate the tip I have read about blowing the ballast tank out but nobody explained how to do so very clearly but that makes perfect sense. Thanks I will pm you if I figure it out lolI started with a Mac 26D (hull number 35). It sails well as long as the ballast is clear full and the dagger board and rudder are clear down. If things don't go your way, just drop sails and fire up the outboard.
In the river is another story. With a 9.9 Honda, I couldn't plan on anything over about 6.5 mph. So make sure you can go against the current. I've found a few places I needed to wait for the tide in Puget Sound. The Colombia tide may take thousands of years to reverse. (Ask another local sailor or even a kayaker.)
Here is a Mac 26 trick worth the admission. When you go to put her back on the trailer: get a 12 volt pool inflator (I tried a cordless one, but the battery gave out a bit too soon), and put it into the vent right next to your ballast valve. Turn on the blower and open the ballast valve. Once bubbles start coming up the outside of the boat, shut your fill valve, then turn off the blower. Your ballast tank is now nearly empty. This reduces the weight loading it on the trailer, and you don't tie up the launch ramp for 10 to 15 minutes waiting for the ballast to empty. You will still need to open the valve once out of the water to drain the last few gallons.
PM me if you want a few more hints from my past experience. These are simple boats but some small hints like this really help.
Ken
Good advice.Is there a lake nearby? Someplace you can practice in still waters? A place to make sure your O. B. Is reliable?
Once you know everything works as it should. Then take it on the river.
This is very true. Every once in a while I forget to lower my daggerboard. Without it the boat will handle fine in reverse but once I try to go forward it reminds me that I need lower it. It only takes about a foot of daggerbard to get her back under control.If the dagger board is all the way up, the boat will not turn well. I have the swing centerboard so dont know how much daggerboard you need down.. but you will need some.
