Lewmar 16 st winch how to remove drum
Jan 24, 2017
672
Hunter 34 Toms River Nj
I can't get the drum off. I don't see how or if it comes apart. I can't believe that it is not serviceable.
This lewmar 16 st winch is 35 years old. I have two of them and they are original equipment on my Hunter 34. They work fine however I could never take them apart to service them. I have lewmar 40 st which ate 35 years old as well that have four set screws on top that are removable to service. I also have lewmar evo 40st which are even easier to service.
I looked at lewmar website archives and they have nothing on this mode.
Has anyone removed the drum to service the bearings on this winch?
I have showed this winch to a number of yard technicians with no luck.
Lewmar 16st. 1983 model
Look inside the winch handle hole. There may be a screw there. Unscrew it and parts just lift off.
Gunni
Mar 16, 2010
5,937
See those two little dogs 180 apart on the collar that surrounds the handle socket? Take a soft device (hardwood) and tap them left. That will free the drum and get you to the innards.
Gunni can he tap the arm of the stripper counter clockwise and get the same results? Or does he need to unscrew the center plate counter clockwise then lift the barrel of the shaft?
Gunni
Mar 16, 2010
5,937
No, the stripper is keyed into the winch frame to keep it from rotating under use. Lewmars disassemble from the locking collar. Should be finger tight.
Jan 24, 2017
672
Gunni,
I don't see any dogs on the top of the winch.
It's not like any of the newer evo styles lewmar makes today.
The stripper arm and entire top of the winch one cast piece, the drum rotates around the top section.
I have tapped on the stripper arm before and it will not move.
I am thinking that this is machine pressed on and is not serviceable.
Jan 24, 2017
672
Thanks John,
That service manual is basically how all the lewmar winch come apart. Most the evo are similar.
This is like non other that I have ever seen.
Stupid design or just my ignorance?
Anyway still can't get it apart.
Johnb
Hunter 37-cutter Richmond CA
See the pictures. The circlip is in the groove on the outside of where the winch handle goes in. I just gently levered it out with a small screwdriver. They can be re used or purchased as pat of the rebiuld kit
672
Eureka !!! Its off, mystery is solved. Yaaaaaa
"Skipper" win's the prize.
I owe you a bear!
Thanks for you link.
For 30 years I have struggled with this stupid thing.
Very poor design.
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
I owe you a bear!
Very poor design.
Actually, it was SBO moderator Maine Sail who helped you.
Pbase is his web site.
MitchM
Jan 20, 2005
1,031
brilliant photos of the winch cleaning process! thanks ! ( but does not make me want to rise off the couch and go into the dark cold rainy night to rebuild my winches...)
SFS
Aug 18, 2015
2,100
Currently Boatless Okinawa
^ Mainesail puts a lot of time, money, and energy into that website, for the purposes of enlightening us all. If you like it, explore further - and consider sending him a few bucks, and/or buying something from him. For example, he sells the world's best butyl tape for bedding hardware.
Aug 3, 2012
2,542
I agree with Gunni. That center plate is finger tight. It was on my Lewmars
