The leak is coming from the centre of the bow . The cat 25 anchor locker is a pan attached to the deck there's a drain hole directly center , water seems to be to be coming in the area that allows the chain , so I was thinking of sealing where the pan attaches with the small " squeeze tube " as the locker is a tight spot I understand that polyurethane sealents cure with moisture .What and how were you going access, then seal that -- before you discuss the 5200?
What is the nature of the leak?
I live and sail in a temperate rain forest , is more not better in this case ?Overkill.
4200.
No, more is not better.is more not better in this case ?
Torrential downpours the last few weeks , may have leaned towards overkill like you say . I'm headed out to the marina tomorrow and would like to try to deal with the problem , it will be a wet repair , I'll look into the 4200No, more is not better.
Edit: what makes you feel that the climate there calls for 5200?
It's draining below and into the v- berth and and the locker below , about 2 cups a week , has been raining everydayIs the water draining into the cabin below or bilge from the pan? If the leak is from the anchor lid then, then filling up the pan?
Net
Isn't there a drain relieving the water through the side of the hull at the bow?
If the water is coming down the forestay, for example, then there are different approaches.
