Ok so I realize this is an older thread but how did your extension work? I have a similar issue that I need to repair this spring.
I have a Catalina 22 wing keel on a modified trailer. Make, model, etc.… tags are unreadable on the trailer but that is not what matters. It has an extendable receiver that looks to be about 10’ from trailer front to ball when extended. The extension is 1 ½ square tube (wall thickness unknown) that when extended bends over 2.5’ (yes feet) to the ground. That makes it useless as even the trailer jack can’t be lowered far enough. So I drilled holes to shorten the stopping point to about 6 feet of extension. However the thing still bends over a foot and I know I am playing with fire as the extension is permanently bent and is a pain to put back.
To answer the obvious questions in Minnesota the ramps are designed for fishing boats and almost all of them are very shallow so I need the extension at every launch. I am trying to find a cost effective way to solve this and your plan looks the best. However I am concerned with what tube size to use to alleviate bend and allow me to stand on the trailer to winch the boat up tight. I was thinking of adding a 3” ¼ wall square tube and mounting it under or beside the current hitch in a short section of 4” square tube so that it will slide back and forth but perhaps this is over kill.
I believe modifying the current main tube will be cost prohibitive as it would involve structural changes to the trailer frame itself as you can see in the photos. My question is will the 3” tube support the weight or is it too overkill? I am estimating the load at the front of the trailer with me standing on it to wench the boat from the water at 800lbs or so after the weight of the new steel is added ( 120lbs steel, Me @ 260lbs and tongue weight 420? guessing). Doing the math using the axle as the fulcrum to the hitch the total span is about 20 feet and I think the tube will bend 2.243” (inches) but the whole assembly will add over 120lbs to the front of the trailer.
Is this a bad idea? Does adding the extension off center affect the ability to back the trailer straight? Should the extension be welded to the trailer using larger tube or will U bolts work? Does anyone have a better idea? Currently the boat is buried in the snow but this spring this will be one of my first projects for the year and I want to get everything lined up. I am mainly asking around to see what works best and @Cincy020 you seem to have the best looking setup I have found that wont break the bank.
