Re packing stuffing box, 84 303
Nov 23, 2016
2
Pearson 303 Channel Islands,Ca
Due to excessive dripping, I was looking into re packing my stuffing box. Would like to use the dripless GFO packing material and was not sure if this is compatible with the bronze driveshaft. Any advice?
Lots of opinions. The dripless GFO has followers. Read all the info on the product. Some products are less kind to the shaft. The dripping is the way the system cools the shaft. I go old school and monitor the tightness of the stuffing box to minimize water.
Great article Stu. Also the link to the images from MaineSail should be in the "101 Stuffing Box" curriculum. Great stuff.
Jan 30, 2012
1,154
NO graphite packing/or products in contact with bronze shafting. Ever!
I do not have pictures of graphite/bronze damage - but I think Maine Sail might.
Charles
Jan 4, 2006
7,767
I would have to agree with Charles here in that without knowing the composition of the bronze shaft, you are opening yourself up to a world of galvanic corrosion. As stated in the ABYC P6.7.4 ........................
This is intended to cover the most corrosion prone materials. Once you get into the hi-chrome SS's such as Aquamet, graphite is not a worry. I would recommend teflon impregnated flax and remove any worry about galvanic corrosion.
