Boat speed decreased by 1 knot
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
Yikes! Did that prop ever spin during the 2 months or is the boat actually a slip-condo?
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
fstbttms: My boat does not grow any of that stuff. I said just slime, which is only about 1" fine thickness. By the time it dries it is basically just the ablative paint with a loose powder like stuff on it. If I had any of that growth I definitely would clean it! Chief
Beneteau 323 Annapolis MD
[QUOTE="Warren Milberg, ... Do you think this would slow me down? ...QUOTE]
Post 18: Geeze... it looks like you snagged a wooly mammoth.
mytime
Aug 26, 2014
86
Hunter 2007 Marlow Hunter 33 Middle River, MD
Some of these anode comments are an indicator of the belief that only about 20% of sailboat owners are competent sailors. The rest of them merely OWN a sailboat! Chief
Why do you need to be a "Anode expert" to be a competent sailor?
Likes: Hello Below
Apr 22, 2011
976
The following is a cut and paste written by a New Zealand sailor and electrical engineer:
"It could also be that, in some cases, overdoing the number of anodes may encourage bronze parts to foul up with marine growths:
George Taylor (retired editor of the magazine 'Practical Boat Owner' observes that bronze cannons from ancient warships are often recovered after centuries of submersion in excellent condition and free from marine growth. However when bronze propellers are protected by large numbers of zincs, they frequently grow large amounts of weed and barnacles. If anodes are not used propellers can rot away but remain clear of marine growths.
The most likely explanation for this is that when left to its own devices a small amount of copper is leached from the bronze which discourages marine growths. By using large amounts of zinc, this leaching is reduced and so barnacles, weeds etc. can take hold, but there is a delicate balance to be obtained between using just enough anodes to balance out any corrosion currents without blanking off just sufficient copper release to deter fouling."
Nov 26, 2012
2,315
mytime: not knowing basic concepts for anode use can result in high bucks mistakes. Thats far from an "anode expert".
All you need to know is provided for you by post #11, fstbottms. Copy it. Chief
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Two shaft anodes is not excessive, IMHO. Also, I've never noticed a correlation between fouling rates and anode quantity.
Likes: mytime
on find out sometime in November. I've never had an ablative paint on the boat before this season
The other thing I have noticed is that I don't obtain the speed while motoring that I did in fresh water
Ablative paints are often slower than hard, so that might explain the speed difference.
As for the use of zinc vs Al or Mg in brackish or fresh water - isn't zinc still less noble than what needs to be protected? So if there's not enough corrosive effect to deteriorate the zinc before it self-insulates, then why would other underwater metals be at risk? (Ignoring the possibility that you deactivate the zinc then travel somewhere more corrosive).
Really? 15-20% slower? Give me a break.
Calm down, I was replying to Scott, who said he's going slower, but didn't specify by how much. I agree it shouldn't be the cause for the OP losing a full knot.
A ridiculous assertion that ablative paint is slower than hard all else being equal? Someone should tell all of the racers who use VC17 and hard epoxy based paints rather than ablatives. Also someone should tell that to Interlux, who states - "The club racer is usually better off with a higher level of antifouling protection offered by a Micron® product, while Grand Prix level racers prefer the hard and slick surface provided by a VC® product or Baltoplate". (http://www.yachtpaint.com/literaturecentre/winning_boat_concepts.pdf). While they don't quantify the difference, I'd hardly say such an assertion is ridiculous.
Feb 26, 2011
1,440
All else is not equal. The reason racers like a paint like Baltoplate is because it can burnished to an extremely smooth finish, which is not the case with an ablative paint. Hard paints are not by nature faster than ablatives.
To make a blanket statement that a 20% difference in speed is attributable to anti fouling paint type is absolutely ridiculous.
