I plan to do some more solo sailing mostly because i know no one else that sails besides my family, question is has any of you sailors ever gone over board while solo and have to watch your boat sail away or know someone who has!
A PLB would be a safer bet than the cell phone. But as you say, just don't fall off in the first place.Plan on not falling off. It's pretty much a death sentence. The only time it's not just when fate intervenes and you're very clever. Or on a small lake filled with warm water.
A few years ago, French sailing star Florence Arthaud fell off her Vendee boat during a pee off the transom ... she had her mobile phone with her in a lifeproof case. She called her mom in Paris and she organized the rescue.
Yep. I have an inreach SE that I use for the same purpose. But do I have it with me 100% of the time of the boat? Nope.A PLB would be a safer bet than the cell phone. But as you say, just don't fall off in the first place.
Personal locator beacon. It's essentially a mini-EPIRB. (Emergency Position Indicating Radio Beacon)Plb?
Staying on is one thing but have you thought about how you would get back on if you fell off? Even if you fell off at anchor and the boat is not moving, it can be really hard to get back on without a boarding ladder. My most recent boat and my previous boat both had swim ladders that I can/could reach from the water. Do you have a permanent mounted swim ladder? If not, can you climb onto your O.B. from the water? Or rig a knotted line on a stanchion that can be reached from the water?... just pulling anchor once i was nearly over, no real harm there but that started my thinking
This would be my suggestion. Electronics are great but a jack-line will keep you on the boat. Not falling off is always best.rig up a jack line and a harness and stay clipped in at all times and you will be safe
Now there is an idea for an app. Detects you are no longer within one boat length of the receiver. Detects your last known position when the signal stopped responding. Turns the boat around and heads back to the last known position. Then does a heave-to and waits. Cool.Along these lines it occurs to me that it would be a cool thing if you had a gizmo clipped to you that would send a signal to the autopilot to turn the boat around if you fell overboard. Does that exist? I realize that turning around a sailboat is not as simple as just turning the wheel but you get the general idea.
Yes, I use and recommend a double tether, it makes it much easier to move around shrouds as you go forward. I also run my jacklines high (on a shroud hook) so that if you fall, you are likely to come up short before you tumble over the lifelines and leave the boat. Always wear a a non-folding knife too so I can cut my self off the tether. Q: Is that InReach device IP7 waterproof?Question: has anyone here that's recommended Jack lines ever use them on a routine basis and in the real world ocean conditions?
You don't say anything about the size and temperature of the water you will be sailing in. I frequently single hand on San Francisco Bay andI plan to do some more solo sailing mostly because i know no one else that sails besides my family, question is has any of you sailors ever gone over board while solo and have to watch your boat sail away or know someone who has!
Well, yes. And, I worry a lot about them. I have more often nearly fallen tangling on the jack line, tripping on it, or coming up short than without. Yes, I rig them and use them but find them a danger.Question: has anyone here that's recommended Jack lines ever use them on a routine basis and in the real world ocean conditions?
