Wiring Connectors...
Aug 23, 2014
164
Catalina 310 Guntersville, Alabama
I'm sure this is old hat to most of you but I have never replaced a raw water pump. It is pretty straight forward but I need help about what type of connectors since it is a straight wired pump. The old one doesn't look too professional so please offer your advice. Thanks.
11,759
Heat shrink butt splices, using the correct crimp tool for the terminal....
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
I use wire nuts even though most mariners say no. My experience says to oil wire ends, fill nut with grease and twist her on! Use only inside though.
Chief
11,759
Chief
You will fail an insurance survey, if the surveyor is actually competent, by using wire nuts, and should..
Nov 30, 2015
1,343
Yep, I second the motion for Crimpable, Heat Seal Butt Splices...couldn't be easier and offer protection (if heated and shrunk properly) even under water, like in the bilge.
Likes: MrBill_FLL
One of the most important things you can do for your new installation is to use PLENTY of wire and make a big loop. Why? 'Cuz the other day we were contemplating a replacement of our fresh water domestic pump under our galley sink. The OEM wiring was pretty tight, and the butt connectors were almost impossible to get to. Sure, I would have cut the wire off closer to access, but then I'd have two butt splices where only one would be required.
Plan ahead for the NEXT time, so it ain't so hard to do.
Likes: SFS
May 4, 2005
4,062
I'm a belt and suspenders guy.
I'd coat those heat shrink connectors with plastic dip. (liquid electric tape).
-does any one recommend soldering the wires?
Mar 1, 2012
2,182
And buy a decent ratcheting crimper.
And no on the soldering, although when in Naval air, (long long ago :)) I did a lot of soldering of wires in the old AD Skywarriors
Aug 23, 2014
164
You are so right about leaving extra wire! The old splice was under the water tank.
Aug 23, 2014
164
Thanks all. Install and prime the pump? Never primed the old one so not sure about that either. It is a march pump. Centrifugal mag. I guess just make sure it has water coming in to the inlet hose from the seacock and turn it on...
Apr 22, 2011
974
March pumps are not self-priming. That's why the installations I have seen are below the waterline. But you can still get air in the inlet hose when you haul out, or in your case, when you install a new pump. What I did was to slip the raw water inlet hose off the nipple of the pump, open the seacock, and then push the hose back on the pump. It's not good for the pump to be run dry for long.
Aug 3, 2012
2,542
I like the BSP adhesive heatshrink connectors. I bought a kit which includes the different connectors in 3 sizes, crimper, and torch. Good advice on leaving a loop!
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
ABYC says no soldering - use crimp connectors. And avoid taping them - they have to be visible so you can see if there is corrosion.
My favourite "connector story" was on my Catalina 36, which was a charter boat when I bought it. It was obvious a lot of users complained about the batteries not getting charged, and the Charter company did a lot of quick fixes: bigger alternator (not properly lined up), bigger house battery... I had a look at the wiring. The charging wire (about 14 Ga) went from the alternator through a connector to another connector at the control panel, through an ammeter, and back through the two connectors.
Guess what? One of the connectors was so corroded there was about a 1/8" gap the current had to jump across to get through! I replaced the whole wiring with #2 welding cable, through an ammeter on the DC panel (with properly-done connectors!) and to the battery switch. Charging current went from 5 A to over 30 A.
I don't understand why boat companies try to save $20 on wiring on a $150K boat.
druid
Likes: agprice22
JamesG161
Feb 14, 2014
8,019
Hunter 430 Waveland, MS
he may use them in a whatnot to do article
Well since I have a copy of at least 2003 E-11 ABYC, because of Maine Sail;), I will not give an opinion but let you read the section of the discussion on to solder or not to solder.
But...
I was taught to mechanically connect the two wires first,
which if twisted together properly works and/or, as Maine pointed out... properly crimped.;)
Jim...
PS: Woodster, I ain't rubbing my azz or :redface: yet.
JamesG161
Feb 14, 2014
8,019
oops I forgot the Tensile strength or mechanical strength requirement for the connection.
Jim...
PS: Hmmm I would how many FIG Newtons it takes to make 44 Newtons?:p
3,961
Corsair F-24 MK I Deale, MD
Mainsail covered this, and yet we go on and on.
Even the USCG bans wire nuts outside a waterproof enclosure. The answer is simply NO.
Heat shrink IS the belt and suspenders. Properly crimped, a butt connector will not fail, even under water for years. The concern is stray current; make certain the connection is not in the water (the bilge should be dry, but that is another topic).
Twisted together and soldered does not meet the code. That is not a mechanical connection in this age.
Why even consider any of this Mickey Mouse stuff when even Home Depot sells everything you need to do the job correctly? Ever had a fire on board because of faulty wiring? I did (PO short cut twisting wires together, yes I was offshore). It will get your blood pumping since there is no place to go. Is that something you want to do to the next owner? If you can't do it right, just don't do it.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Jim...
that would be a bell splice for sure ....
if you do a bell splice and solder at the proper heat and alloy ..... then cover with transparent heat shrink you should be good to go ....but i find it a lot easier to butt connect and heat shrink when in the water than solder
Likes: JamesG161
