Hi All,
I have been working on this design now for a while and finally have a workable prototype (patent pending for upper mount). The first few attempts at this were scrapped. The product is a mount design for a 10W - 50W solar panel to be mounted aft of a back stay on a sailboat. It is intended for mooring sailed boats or boats in a marina with no power. The benefits if this solar mount are...
#1 The solar panel and it's sharp edges are up and out of the way well above head height.
#2 Provides the strength / space for up to 50W of solar for boats that do not have davits, bimini's, dodgers or suitable places to mount panels out of harms way.
#3 Limits shade potential from boom or radar poles meaning higher daily performance from a small panel.. Back stays don't impact panels as much due to the way the light bends around them.
#4 By utilizing the back stay for fore/aft and lateral support we do not need a large diameter pole and we don't need support struts. Just a single 1" pole will support the panel.
#5 By drilling two holes at the top and bottom of the 1" pole this allows PV wires to be hidden inside 1" pole and to exit just a few inches above the deck.
Unfortunately the components are not inexpensive at this point in time. It is looking like the top mount with the split UV Delrin back-stay bushing is pushing $165.00 (to the end user) and the lower mount with backing plate is pushing $120.00. Working with 316SS and having it polished cut and welded, in small lots, is expensive. If anyone out there does this, and want to quote this, please contact me..
To allow the boat owner to source the best prices for the other parts, SS tubing and fittings, the rest of the components are standard 1" dodger fittings. For strength the eye-ends and jaw-slides will need to be center drilled for a 1/4" fastener to through bolt the assembly together and I plan on offering these as well but the quotes I have now from 11 machine shops, just for center drilling the 1/4" holes, is averaging about 6.50 per hole (my cost) plus the fitting.
I am trying to determine if this is a product boaters, other than my direct customers, would be interested in. I have three scheduled to be installed in August. It is still in the prototyping stage but will be ready for prime time pretty soon.
This is a bench mock up:
*The thin wire passing through the Delrin bushing represents the vessel back stay. The bushing is drilled to finish diameter, using the 1/8" pilot hole, by the end user. The bushing simply rides on the stay and it is not a "tight clamp fit" but rather the hole is ever so slightly larger than the stay.
*The aft facing solar mount is created using 1" .065 walled SS tube, 1" SS Eye Ends and 1" Jaw Slides. The top and bottom eye ends will need 1/4" holes drilled with 1/4" though bolts as well as the top jaw slide and the innermost eye end for the aft facing solar mount.
*The lower mount comes complete with a deck plate, backing plate and bolts. This mount plate may not work for all boats so alternative options for the bottom may be necessary..
*The main upright pole is designed to be 7' to 8' above deck or high enough for the panel to clear boaters entering and exiting from the stern ladder.
