Okay, fellow sailors and wing keel experts. Finally took a look at my wing keel. I don't know if I'm going to be able to get out on the water before the end of the season. The wing keel mount is going to need to be repaired or replaced. Am I screwed? I know I need to replace the bolts and will probably have to replace the pin and brackets. Question. How do I get the bolts loosened? Is there a special socket to put on the head of the bolts? I see that I will be tapping the threads out on the port side of the keel. Here are some pics.
