The simplest solutions are often the best. thanks for the transport tip folks. tomorrow I'll pick up some duck cloth and sew up a condom for it. Less wrinkles in the sail cloth, less grit and grime, yet it's even way less hassle than folding. I love it!
It could be rolled up with the battens installed, but the sail cloth and battens will be much happier with at least the top two removed (4 batten Doyle sail) due to the angle that they install in the sail.
As to future reefing this way, it might be better to remove the bottom batten to reduce sail wear in the pocket, but even for the second reef point the first batten is the only one affected.
Thanks again all,
RussC
Thanks again all,
RussC
