Thanks, Rick, for the encouragement! I have a great guy working on it now that got his running so I'm excited!
Just learn to do a compression test. It's not difficult. That will tell you a great deal about the internal condition of the engine itself. Anything else that needs fixed will likely be cheap stuff.Thanks SFS, I guess I'm stuck with the outboard for now as I seem to have spent all my available cash on the boat, the outboard, sails, slip rent and all the rest that goes with boat ownership! I've been in contact with a guy in Maine that has two for sale, he also wants me to send pictures so he can assess it from afar(I'm in SC). I've got a bad case of Champagne tastes with a beer budget. Like my Dad always said "po' folks got po' ways", but I've got the sailing bug and it's one of the joys of my life! What's it like sailing in Tampa Bay? One of my sailing buddies(who also used to have a Hunter 31-great boat) is down there this weekend and I'm green with envy.
I'm stuck here in SC sailing on a roughly 50,000 acre lake. I'm rambling here so forgive me! Thanks for taking the time to respond! Lee
Lee,Kermie, I've been on Lake Murray since I was nine! I'm 63 now, do the math: I love this lake. What I meant was I'm not sailing the ocean blue and going where the wind blows me! I will always love Lake Murray and just to be clear, I have left explicit instructions for my ashes to be scattered on this "great" lake after cremation, I will never leave this lake!
he wants to know when he turns it in........ do you want it with or without frog legs Kermitp.s. You still haven't turned in your assignment.
Just wondering were you able to turn it over before you removed the head? If you did turn it over, did you do a compression test?OK. Proof in the pictures. And today, I managed to take out two of the remaining four head studs, and prepped the other two for drilling. (Prep --- ha ha hah. That means I snapped them off at the block, but not too bad. I will drill them out, next week.)
Regarding the rebuild, I spoke to Don at Moyer Marine (www.MoyerMarine.com). The plan going forward is to remove the last two studs, order a new set and put them in, put in the head gasket, and them do a compression test. Someplace in that list, I need to turn the motor over several times and clean the valves, for sure. In at least two of the valves, head gasket like material was caught between the valve and the seat, along with LOTS of carbon. The engine block, between cylinders two and three, had a shadow, and artifact of communications between the pView attachment 122553 View attachment 122553 View attachment 122553 iston areas.
No. Four of eight head bolts were already out and the remaining four were twisted off at the top of the head. So, to go forward, I had to get the head off, remove the last four studs (now I have only two to drill out), clean the cylinders well, put the head on, and then compression test.Just wondering were you able to turn it over before you removed the head? If you did turn it over, did you do a compression test?
