1973 Pearson 30 with Atomic 4
Jun 9, 2008
1,814
- -- -Bayfield
There are some good books on A4 maintenance including the original owner's manual. But, if you get any mechanic to check the ignition (i.e. spark to the components of the ignition system: spark plugs, points, coil, etc.). There is a simple procedure to access this. Some Atomic 4's don't have points in the distributor, but instead have been fitted with a CD ignition. If you have a distributor with points and a distributor, it has been my experience that the points are the problem. You can buy them from Moyer, Marysville Marine, Napa, or any good boat store that handles such things. You gap them the thickness of the box they come in (like a match book cardboard thickness). Most of the time that is all they need. If the ignition components are in good condition and the engine still does not start, then you must check out the compression of the cylinders or the fuel to make sure it is not dirty, has water or another contaminant in it. It would do you good to learn up on this stuff. It is not that difficult, actually.
Nov 10, 2015
195
Hunter 336 Columbia, SC
Thanks for the input and for taking the time to respond BB! I took some photos and sent them to a guy in Maine that rebuilds them. He reported that the engine was probably done. He's got a rebuilt one and a used one that he's hoping to sell. I would love to buy either but now I'm leaning towards pulling the engine out and getting a mechanic to repair the one I have. We shall see!
Apr 22, 2009
342
Pearson P-31 Quantico
My Atomic Four died. So, I redid my Atomic Four.. On youtube you can search for "RobertLangDirect"
Video with head off and new valves
Starting the REVALVED and NEW HEAD GASKET atomic four. This was ACTUALLY, REALLY, no kidding, the first crank after we put everything together.
Moyer Marine encouraged me to rebuild rather than order a new engine, BTW. Thanks -- Moyer Marine!
Apr 22, 2009
342
I also helped a friend pull out his engine from a Pearson 30 and install a new (rebuilt) one. Easy to do with BOOM, COME-ALONG, and four or five friends for the manpower.
Nov 10, 2015
195
Bob, that was an amazing feat of perseverance! I will NEVER tell you that you can't do something or that it can't be done. Impressive to save the very least! Thank you.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
i have wondered over the years...looking at that engine i keep thinking it was some kind of marinised continental industrial engine like found on the 4 cylinder SA200 lincoln welding machines
Nov 10, 2015
195
Ray, thank you so much for recommending to Bob that he contact me! That is amazing that you wield that kind of power! I am summarily impressed! And from far away too! Ha ha! Bob is a magician with that engine! Incredible for sure!
Kermit
Jul 31, 2010
5,704
I'm stuck here in SC sailing on a roughly 50,000 acre lake. Lee
Ahem! Stuck? Seriously? Lee, Lee, Lee. You're "stuck" on one of the finest sailing lakes in the USA! Now write 100 times, "I love sailing on Lake Murray." It's due by lunch tomorrow.
Nov 10, 2015
195
Kermie, I've been on Lake Murray since I was nine! I'm 63 now, do the math: I love this lake. What I meant was I'm not sailing the ocean blue and going where the wind blows me! I will always love Lake Murray and just to be clear, I have left explicit instructions for my ashes to be scattered on this "great" lake after cremation, I will never leave this lake!
Likes: woodster
Kermit
Jul 31, 2010
5,704
How are you coming with your assignment?
Mar 30, 2013
700
According to everything I've read the A4 was purpose designed and built to be just what it is. While there are some similarities with other small "F" head 4 cyl engines the A4 is the A4 and not a modified or marinized something else.
Nov 6, 2006
10,133
Yup.. It (the Atomic 4) does look similar..but the block is cast from a different metal.. If I recall correctly, it is a higher nickel cast iron for corrosion resistance.. but there apparently are no interchangeable parts with the Continental 4 cyl flathead motors and its cousins in welders and various old military stationary generators, and old Willis Jeeps etc. I did a dimension search because I figured they were a common block, but I found nothing to verify my curiosity. One strangeness is the power take off is opposite the flywheel..
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
Just remember if you change to a diesel, the motor is not the only thing to change. Fuel tank, mounts, trans/reversing gear, and possibly shaft. At the very least modify the shaft.
That was the main reason I rebuilt mine instead of replacing. The cost was not in the cards for my old girl.
But this is coming from a guy that motors maybe 10 hours a year.
Nov 10, 2015
195
I love my Atomic 4, Bob's purrs like a kitten! I would never change unless, of course, someone offered me a free replacement and by the way offered to make the switch too! The chances of that are slim to none so I guess I'll stick with plan A but thanks for the advice!
Oct 1, 2007
1,865
Hi Sailors, I would like some opinions from those who have experienced a similar situation. I recently purchased a 1973 Pearson 30 with an inoperable Atomic 4. The boat is in decent shape and has a new main. She's in need of a new headsail and I hope to get one soon(I'm looking on Bacon Sails). I also purchased a new 9.8 Tohatsu 4 stroke that is awesome but of course it's a PITA to get to and maneuver around the marina(stern pulpit). I don't know anything about the Atomic 4 but I hope to get someone to look at it in the near future. What would you do? I respect & value your opinions. I hope to make up my mind soon!
I owned a P30 years ago with the Atomic Four and it was a reliable, simple engine. It is carbureted with a conventional distributor based ignition system. Any qualified gasoline engine mechanic can give you ana assessment of what it might take to get it running.
