Hi All
I wanted to share my experiences installing a solar panel on the mast crutch pole of my H26. I found a really nice company called Arizona Wind and Sun and I called them and talked to a guy named Robert Snipe and he very carefully talked me through the project and made sure I had the right parts.... and he didn't even try to sell me stuff I didn't need
. Anyway, I now have a small solar panel mounted to my mast crutch that puts out 0.57 Amps so I should hope to get about 6 Amp-Hrs a day. Total cost was $146 with shipping. I already had the plug through the hull so add another $5 for a trolling motor plug if you need that.
The mounting bracket connects to the pole using two worm screw clamps (large hose clamps like the ones you use to attache exhaust hose to the dryer). I drilled two holes through the mast crutch pole and ran the electric through the pole. The rubber grommets I got at Lowes and they are to keep the sharp edges of the holes in the pole from chaffing the electric lines for the panel. It took me less than an hour to install. Here are the pics and part numbers.
